Page 3 of 3 FirstFirst 1 2 3
Results 31 to 34 of 34
Thread: 1972 R75/5 Voltage to Ground Question
  1. #31
  2. #32
    Pismo Beach, CA
    Thanks Josh.
    The "previous" post was seven months ago. Did this problem get sorted out?
    Last mentioned it was looking like a "wiring" problem, and it was previously noted by the OP that the "green/black" wire has melted.
    Lucky for /5 owners, a complete, new, wiring harness is only about a $150 investment vs. $500-650 for the /6 and later models.
    Lew Morris
    1973 R75/5 - original owner
  3. #33
    Registered User j_withers's Avatar
    Feb 2012
    Culver City, CA
    Arrow
    I think the main harness is only $65 for a /5.
    Regardless,
    I found this thread while investigating a possible issue with my /5.
    I posted the link just in case anybody else discovers this thread.
    I too am curious as to if the problem was solved for the originator of this thread.
    I have a completely restored /5 that I just started up for the first time. I am using a Shorai lightweight battery and it died within my first 60 miles. I'm checking over my electrical system to see but I can't find a voltage leak.
    Rotor checks out.
    Diode is a Enduralast diode board and it tests OK.
    Dyna electronic ignition.
    Brushes are OK (about 75% left)
    I did a Rocky Point ignition key replacement instead of the /5 key system.
    All new wiring although I added aftermarket turn signals and tail light.
    I had a bad starter relay that I switched out.
    Voltage regulator seems to be pushing out 13.8V on the revs and 13.2 on the idle.
    I may be fine but just going over the basics to be sure.
  4. #34
    Pismo Beach, CA
    You are correct sir. My /5 ref was for the "main harness" + "engine harness" + "sub frame harness" + "turn signal harness" (front)
    Might try another battery. It wouldn't be the first time that a "new" battery was defective...
    Lew Morris
