Results 1 to 6 of 6
Thread: R90/6 '76 - Leaking petcock
    Registered User plehman's Avatar
    Nov 2006
    Arlington, MA
    Working on the headset and noticed a little gas puddle. What? did I leave a petcock open? Is the cork leaking or the float bowl not seated properly? I pulled the bowl down and gas, gas, gas. Just filled it up!
    Question. Could the gasket be bad? Number 5 on this page. What else fails on petcocks? They were updated at some point in the last 10 yrs.
    http://www.maxbmwmotorcycles.com/fic...9&rnd=04302013
    Nov 2006
    Arlington, MA
    Actually you have to see Diagram 16 0225
    It's not clear where the gas is leaking from. Is it coming out of the bowl, is the hose leaking, is it leaking around the petcock, above the petcock? Need to know that first. Item #5 is something that rarely needs replacing unless it's been cracked...in which case the hose won't seal on it.
    Nov 2006
    Arlington, MA
    Right. Saw the leak. Removed to bowl to make a better seal and the gas didn't stop. Usually when I take off the bowl and the petcock is closed no more gas comes out. Maybe it was just what was in the line and inline filter. Will try again tonight.
    Pismo Beach, CA
    Easier to see when the page is posted.
    Gasket (#7) can become hard with age and leak.
    Keep in mind, with the cross-over fuel line through the air filter box in place, it could be the "other" petcock leaking.
    Lew Morris
    1973 R75/5 - original owner
    Nov 2006
    Arlington, MA
    DIY can equal dumb, idiotic, yanker
    Thought I checked and often don't even open the right petcock. Sure enough it was wide open.
    Basics man! Why do I always jump to the catastrophic?
    Thanks for your patience.
