Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: best jacket for the fall and winter
    Registered User arptra's Avatar
    Feb 2006
    Dallas Texas
    does any one have suggestions on a good riding jacket mainly for cold weather, I have a mesh jacket for summer. I have been looking at first gear but they have about 4-5 different styles available, I'm mainly I would just like to stay warm.
    Wilmington, NC
    Brands are more of a budget subject.
    If warmth is your primary goal you need to remember 3 things when selecting
    1) Layers
    2) Windblocking
    3) An electric for underneath when really cold.
    Cold weather jackets should typically be 3/4 length, longer than your summer mesh..
    got, got, got no time... rguy's Avatar
    Aug 2003
    Rogersville, MO
    The brand is secondary in my opinion. The best winter jacket is one that fits properly, especially around the neck. Is the collar too tight, too loose, too short, too tall? It will drive you nuts otherwise. Do the cuffs fit well with your gloves? Personally I have a First Gear Kathmandu. The collar fits my stubby neck well - a little loose. With the liner removed it accommodates my heated liner well. The sleeves fit well as does the torso. I went to several dealers and tried on a BUNCH of jackets before I found the one I liked. The folks at MotorcycleGear.com do an excellent job of describing the fit and quality of their jackets. They have a great selection too.
    Neal - '09 R1200GS / '81 R65
    _______________________
    Be the person that your dog thinks you are.
    vancouver ,wa
    Also what price range you want? Just boughtv a $200 first gear jacket , but could have spend up to $600.
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    1) Layers
    2) Windblocking
    I've used various combinations of jackets over the years and have found that the combination of electric inner liner, wind blocking mid liner, and waterproof outer shell has worked best for keeping me warm. My current setup is a Darien Light. The outer shell keeps the water and lots of the wind off of my body. The addition of the wind blocker liner keeps the rest of the wind out and my body heat in. I use that combination down to the upper 40s. I'll add a warm-n-safe electric liner under the wind blocker liner to keep me warm in any temperature I care to ride.
    2009 R1200RT beemeup's Avatar
    Portland, Maine
    Jacket
    I just got a Klim Latitude outer shell that is gore-tex and guaranteed waterproof, it's really a great quality piece of equipment and I'm quite pleased with it so far. Under this I would use a mid-layer or a Gerbing's heated liner depending on how cold it is outside. The beauty of using a shell is that it allows you to layer underneath based on the the conditions and with a good shell it can be used any time of year. The Klim is the best shell I've ever had and the sizing is true to their chart. Good luck with your choice.
    Feb 2006
    Dallas Texas
    Thanks to all , this helps a lot, the first gear is the one I have been leaning toward, I like the Klim but are a little out of my price range.
    vancouver ,wa
    Go to a store with the differant models of the First Gear and try them on first. I ended with a smaller size one than I normal wear and it fits better. A good sales person helps too. I try tour master, olympia & alpenstar but like the first gear best.
    Aug 2010
    Raymond,NH
    I've been happy with the First Gear Teton TPG jacket I bought a couple of years ago. Blocks the wind really well and is waterproof/breathable. Has an insulated liner for colder days. Plus, I got it on closeout for around $99 :-) For me, it's too warm for summer use so I have a mesh jacket for that season as well. Any of the TPG jackets should work about the same but fit and coverage will vary.
    Carl
    '93 K75RT
    Feb 2006
    Dallas Texas
    yeah, I have a mesh for summer and in Texas even that is to hot. Just looking for something warm, on coldest days will use my electric vest.
    Alan,,
    Dallas Texas
    89GS, 08 R1200GSA
    Dec 2010
    Not sure what you like of course, but a very good versatile jacket is the Classy Rider .
    I've had one 6 years now and it amazes me. It is light weight, folds easily for storage , really warm for it's weight,, rain [resistant] , and has a decent temperature range , and includes vents. It has a zip closure w/storm flap, & a stand-up collar .
    I bought one size up, to allow a fleece, sweatshirt, etc. under it, and it works very well.
    They have a web site www.ClassyRider.com
    Registered User dancogan's Avatar
    Aug 2004
    SE Michigan
    I really like the Olympia mesh jackets that come with the two part liner: one part is waterproof and the other part is insulated. You can wear either or both with the mesh jacket and the insulated part is very warm.
    Dan
    Registered User nytrashman's Avatar
    Nov 2007
    westchester co. NY
    I recently bought a aerostich Darien light jacket and love it. If that doesn't fit within your budget take a look at the roadgear jackets that Nick sells. They are loaded with features and are very warm.
    100,000+ miler 32232's Avatar
    Southwestern Ontario
    I just picked up a BMW Tourance 2 for 1/3 off. It was discounted as the 2013 styles are now being introduced.
    It's my third BMW jacket over the years and they are the most comfortable I've owned. I had an Aerostich Darien for a decade, but like the BMW jackets better, mostly for a more tailored it and nicer finish.
    Dave
    '06 Triumph Scrambler (Trans-Labrador veteran)
    Aug 2012
    Grand Rapids, mi
    I have a tourmaster Saber (~$175) - waterproof membrane, windproof, and a zip in quilted insulation liner. I rode this morning in 40F at 75mph and was comfortable. I wear a tourmaster air intake mesh during warmer weather. Held air n dry gloves - which are ok even at 40F with heated grips, but just barely. R1150GS.
