Results 1 to 4 of 4
Thread: lower spacer install '99 F650
    Nov 2009
    Central Ontario, Canada
    Anyone seen instructions of how to install the lowering kit spacers into the rear shock for a '99 F650 Funduro?
    I would appreciate a link if you have.
    R's Graham
    1991 R100 GS "Bumble Bee"
    2007 KTM 525EXC-R True Adventure, 2010 Husaberg FE450
    Past BMWs: '68 R50/2, '77 R80/7, '87 R80GSPD, '76 R60/6, '85 K100RS
    Oct 2005
    NW PA
    http://f650.com/faq/FAQs/LoweringKitFAQ.htm There is a link to the instructions within this link. I have seen reference to people using a LOT of tie wraps to compress the spring to install the spacer if you do not have a spring compressor.
    Nov 2009
    thanks!
    R's Graham
    Nov 2009
    Took the shock down to local shop and for 30bucks had the spacers installed. Saved myself the time to figure out a Jerry rig that would have likely ended in a few curse words
    Wheel no longer bottoms out on the fender, not quite as nice a shock as the ohlins that was on it
    R's Graham
