Results 1 to 6 of 6
Thread: '87 K100 Brake Light Warning
    RK Ryder
    London, Ontario
    does not shut off. When only the front brake lever is applied, the brake light comes on. When only the rear brake is pressed, the brake light does not light. The brake light does light when both brakes are applied.
    In the meantime, the brake hazard light is constantly on and does not turn off when the brakes are tapped. Where do I begin to fix this problem? Is there a rear brake sensor that needs adjusting and if so, where is it located?
    Paul
    Knights of the Roundel #333
    Sounds like your rear brake light switch is bad. It's located at the rear brake lever behind the peg plate. The wiring connector is along the frame just in front of the coolant overflow bottle.
    Jun 2008
    Canyon, TX.
    The rear switch is somewhat out in the elements and can get dirty and gummy. I have used a light lube like WD40 to free up my switch. Hold the brake pedal down and spray into the switch. The little peg of the switch should pop out easily. Work the pedal up and down and spray the switch until it works freely. Cured my problem. Good Luck!
    I believe that he has the newer style micro switch with lever instead of the earlier (pre 9/86 plunger style, like is used on the front brake lever and on the clutch lever).
    Nov 2009
    Phila
    Sounds also to me like rear brake switch.
    Either type leads a hard life. They rely on metal to metal contact to turn on the brake light and turn off the dashboard "brake light failure" light. New switches work great because they are clean inside. As one guy suggested, solvents sprayed inside like WD40 can sometimes restore the "metal to metal" contact inside needed to work properly. My 85 has the round plunger type on both front and rear brakes and rear one has responded to solvent and "working it."
    RK Ryder
    London, Ontario
    Thank you gentlemen for your replies. Took your advice but no success. I have come to the conclusion that I will need to replace the rear brake switch.
    Paul
