Results 1 to 11 of 11
Thread: Clutch Life/Adjustment
    Dec 2010
    Central Ma.
    Question Clutch Life/Adjustment
    I own a 2000RT w/41,000mi. on it. I need to adjust the clutch at the adjuster on the engine/clutch. which side panel do I remove for access(right or left)? I have the instructions from the manual.
    Also, what is the average life of the clutch? I am the second owner and purchased the Beemer w/31,500mi 2 yrs. ago.
    Thanks for the help.
    Apr 2005
    There are probably different ways to do it, but I was able to reach mine by removing the left footpeg panel. It's been awhile, but I think the left-side tupperware needs to come off also.
    Dec 2010
    Central Ma.
    Question Panel
    Are you talking about the black panel attached to the fairing?
    Apr 2005
    Nah, the silver panel. Search the MaxBMW fiche for this part #.
    46 71 2 314 967 FOOTREST PLATE, LEFT
    Dec 2010
    Central Ma.
    Thumbs up Clutch adj.
    found it. A co-worker has a 1100S and I was able to crawl around his and located the adjusting bolt/locknut. It`s right in front of the shock. What a PIA place. Thanks for the heads up.
    Certifiable User Mike_Philippens's Avatar
    Feb 2011
    The Old Country
    The average live of a clutch is hard to say. Mine's got nearly 170.000kms on it (not miles, I'm in Europe) and as far as I can tell, it's on it's first.
    I met a guy at the BMW Motorrad Days who's on a round the world trip on a GS and after 260.000kms he's also on his original clutch. And that's a 900pound bike with all the modifications for the RTW trip. So...if you're nice to it, it will last...
    -=- if you always see the road ahead of you, it's not worth the trip -=-
    Mar 2006
    Access
    Remove the black side panel, use a long extension and flex joint, loosen the 13mm nut and hand adjust the bolt. Set the play. Use Velcro to hold clutch in at handle and tighten.
    Done.
    Quote Originally Posted by rwl1955 View Post
    that is really interesting/perplexing/weird, as looking at the back side of my engine/trans, all i see is a hydraulic slave cylinder- no adjustment capability anywhere at all. and according to Clymer's as regards the hydraulic clutch systems- "there is no routine clutch adjustment necessary or possible."
    All i can think is that maybe your co-worker owns an RS, with a cable actuated clutch, rather than an S with a hydraulic system?
    Sep 2010
    Pleasure Island. NC
    Jerry Dockery
    309 N. 3rd. Ave.
    Kure Beach, NC 28449
    Dec 2010
    Central Ma.
    Thumbs up Access
    Done.
    Thanks, I`ll try your suggestion first.
    Dec 2010
    Central Ma.
    Rs
    __________________
    bikerfish1100 is offline Report Post Reply With Quote
    You are correct, it`s a late 90`s RS.
