Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 55
Thread: Camheads use oil? 2012 R1200RT
  1. #31
    Registered User jkbales's Avatar
    Dec 2009
    Marietta GA
    2010 RT - 1/2 qt in first 600 miles, 1 qt (dino) in next 5400 miles, 3/4 qt (synth) in next 6000 miles. Seems reasonable to me. I'm not far enough past the 12,000 mile mark to say if it's tapering off or not.
    John
    Current: '10 R1200RT Thunder Gray, '90 K75S Titan Blue
    Past: '09 R1200RT, '04 R1150RT, numerous Suzuki, Yamaha, Honda, Kawasaki, & Harleys
  2. #32
    Registered User RT290's Avatar
    Mar 2012
    Sheboygan, WI
    Piston rings or valve seals
    I tend to read all the posts on this particular forum. Call me nuts but I like reading ego battles between members and questions raised by people who have made no attempt to read their owners manual.
    One thing I don't believe ive ever come across reading all the "oil consumption" threads is why the boxer uses oil. Some people say piston rings and others say valve seals. My boxer went through a phase where I burned up to 1/2 quart per 1000 miles. Around 12000 miles it abruptly slowed to nearly a stop.
    I've occasionally come to a stop sign after a hard ride and smelled just a whiff of burning oil. That makes me think piston rings. The traditional inline motor is more condusive to valve seal issues. Oil pooling over the valve seals over night, gradually leaking into the combustion chamber, then burning at start up. To me, the layout of the boxer wouldn't cause oil to pool at the seals. My logic says it ouldnt matter how your bike is parked because oil will not pool at the seals. However my logic isn't always correct.
    Has anyone got an official answer from BMW?
    Joel
  3. #33
    Registered User Alfred02's Avatar
    Feb 2012
    Maybe a reminder or clarification is required.
    Every piston driven combustion engine uses oil !
    The question is simply which amount is excessive.
    Australia N,S,W
    Mid North Coast
    2005 R1200RT
  4. #34
    na1g
    May 2011
    "Every piston driven combustion engine uses oil."
    Well, yes, I suppose so but the amount can be miniscule... or not. A few years ago I rode my Honda ST1300 4,500 miles from coast to coast, mountains and plains, twisties and 4-lanes, temperatures ranging from 35 to 106F. Total oil consumption: about 2 ounces of oil. My 2011 RT has 8,000 miles on it and oil consumption has finally dropped to about a quart in 800 miles. Excessive? Maybe not by boxer standards but that must be about the worst in the industry.
    Not complainin' - just sayin'
    pete
  5. #35
    Feb 2012
    No issues at all with your statement there Pete.
    I just wanted to make sure that Users understand that oil usage (even miniscule) is an inherit function of a piston driven engine.
    Now I am fairly sure that the reason for seeing a cloud of smoke when the boxer is on it's sidestand is that the oil will leak past the piston from the bottom of the piston as this is where your crankshaft housing is that is obviously full of oil and has been spraying around the oil (as it should) to lubricate all the moving parts.
    My old K100RS did the same when on the sidestand.
    I never understood why BMW designed the K engine with the pistons on the LHS instead on the right, so that on the sidestand, the pistons are pointing down.
    Every time I had mine on a sidestand for a day or longer, it used to create a great cloud of smoke during startup. Despite this, the bike never went excessive in oil usage and I just avoided to use the sidestand for longer breaks between rides.
    Now if you look at just about any other bike maker, the pistons all point upwards, which will cause the oil to drain away from the cylinder walls simply due to gravity.
    On the boxer and the old K engines, even on a center stand, the piston/cylinders are still horizontal, so the oil will pool now at the bottom part of the cylinder wall.
    As the piston rings are never a 100% seal to the cylinder walls, a very small amount of oil will leak past the rings and will still be burned on the next startup.
    So to me, the boxer inherently by design will always use more oil then any upright engine (which 99% of the other manufacturers use).
    Anyway...that's my theory using pure logic, but am happy to be proven wrong.
    Australia N,S,W
    Mid North Coast
    2005 R1200RT
  6. #36
    2011 R1200RT ka5ysy's Avatar
    Oct 2006
    Prairieville, Louisiana
    I have done essentially a "Motoman" type break-in on the current camhead RT and my old 07 R1200R Hexhead.
    The RR used about a 1/4 quart of oil the first 600 miles, then another quart over the next 6000 miles. The next 6,000 miles, again the Hexhead used about a quart of oil and at the 12000 mile change switched to full synthetic. At about the 13,000 mile mark, the oil use stopped cold and I never had to add anything between changes.
    The 2011 RT Camhead, which I started driving the day is was unboxed, was taken on a 300 mile break-in run over three days, again the "Motoman" technique with the full warm-up and cool down routines. At the 600 service, the bike had used about a half quart. Over the next 2500 miles as the designated demo bike, I monitored the oil, and it did not use any that I noted, although the dealership might have added some. I purchased the bike at the 2500 mile point, I did another oil change with dinosaur oil at 3000 miles, and ran it to 6000 mile service. Over that period, only about a 1/4 cup was used. At the 6000 mile service I switched to full synthetic, and up to now (6500 miles) the oil consumption is zero.
    MSF #127350 NAUI #36288
  7. #37
    Amateur Veteran R1200RClassic's Avatar
    Jun 2012
    Portland OR
    Quote Originally Posted by ka5ysy View Post
    I
    similar to mine... on my 2012 Camhead, I rode it like I stole it (not quite Motoman, but close and with in the limits of the owners manual) I hit the top PRM's often enough, and I downshifted thru all gears (including 1st).. After the 600 mile service and only 1/3 quart loss, I used a 20W50 Dino thru 1600 miles with similar (although higher RPM, up to 7500) acceleration runs and such, and then topped off the oil with only 2 oz and ran it for another 1200 miles... normal riding. Seeing little to no consumption, I've now switched to a Motul 20W50 for the remaining 3000 miles until the 6000 service... and will remain with that oil for the rest of it's life.. Thus far, in 600 miles on the pure synthetic, the sight window reads exactly the same... 0 consumption.
    2012 R1200R - Classic / ESA II, ABS II, ASC, Heated Grips, Sports Windshield, Computer.
    2005 Honda Shadow 750 Spirit (on cragslist).
  8. #38
    Registered User Gadgetech's Avatar
    Aug 2012
    Greenville, SC
    Mine is a 2012 demo bike. Was almost to the top of the sight glass this morning. I rode the bike about 300 miles today and it's halfway up the sight glass. It's parked in the same spot in the garage on the center stand. Currently have about 3200 miles on it. Always smell burnt oil at a stop.
    Edit to say: The engine was cold when I checked it the first time this morning comparing to 5 minutes after riding for quite awhile. According to the manual could lead to misinterpretations.
  9. #39
    Mike LngRdr's Avatar
    Apr 2012
    Moore, Ok
    Quote Originally Posted by R1200RClassic View Post
    Same here, my 2012 has just under 16K miles in the 4 1/2 months I've had it and very near 0 oil consumption from day 1.
    IBA Number 49673
    Moore OK
  10. #40
    Jun 2012
    Portland OR
    Quote Originally Posted by Gadgetech View Post
    That's VERY high, I'd be very alarmed and take it in for an analysis. Pull the plugs and see how foul they look. You might need to run a large dose of Techron thru the fuel tank once or twice just to clean out the combustion chamber and valves for
    all that burned oil. That's way crazy for 300 miles.
  11. #41
    Registered User RINTY's Avatar
    Nov 2005
    Calgary, Alberta
    ...could lead to misinterpretations...Gadgetech
    ...comparing to 5 minutes after riding...
    Welcome.
    If by this you mean that your second oil level check was 5 minutes after you started riding, then it's not enough time for the oil to warm up, the thermostat to open, and all the oil to drain into the sump.
    Also, at 3200 miles, the engine could still be burning a fair amount of oil, as its nowhere near broken in. I would leave the oil at the dot for now, and check the level after each ride, after the oil has fully warmed up, and has had time to drain for at least 15 minutes after parking the bike.
    Rinty
  12. #42
    Still plays with trains. TinyTrains's Avatar
    Oct 2009
    Torrance CA
    What kind of riding was it? I found that hilly-curvy roads consumed lots of oil when mine was new. It is great way to break it in because those big jugs suck a lot of oil during compression braking, but it does show up on the window.
    Do give it lots of time after you turn it off.
    Half way down the site glass is .25 quarts, so that is a quart in 1200. Not unheard of on a new engine. Toyota thinks a quart in 600 is normal for a Rav-4 or Camery all the time. It is in the manual, but don't get me started on that.
    1988 K75 Low Seat
    2009 R1200R Roadster
  13. #43
    Aug 2012
    Greenville, SC
    Quote Originally Posted by rinty View Post
    Welcome.
    I meant that I checked it cold when it was near the top of the sightglass and at least 5 minutes after my long ride so my results probably aren't accurate. I'm going to do a warm up ride for 20-30 minutes then see what it looks like.
    Quote Originally Posted by TinyTrains View Post
    Yeah, my ride was in the area of NW SC, NE GA and SW NC. All hills and curves just about.
  14. #44
    Registered User wvpc's Avatar
    Dec 2009
    No Where Special
    Update to post #4
    My 012 RT now has 9K on it. It has used an additional 1 quart in the last 4500 miles for a total of 2 quarts in the 8.2K miles since the 600 miles service (done at 800 miles). I plan on one more mineral oil cycle and then a switch to synthetic. I can't complain.
    12 R1200 RT
    83 R100 RT
  15. #45
    Registered User Firenailer's Avatar
    Feb 2010
    Westchester, N.Y.
    Crazy how varied our experiences are. My 2012 RT really uses very little oil. None added before the 600 mile service. 5 or 6 ounces added before changing the oil at 3000 miles, and at 5000 miles no additional oil added and the sight glass still reads 3/4.
    I did follow the manual break in proceedure and RPM targets very carefully, but I really have no concerns about the motorcycles oil consumption. Perhaps the original writer could have the dealer give it a good going over? (Or as has been written in another website, just take it out for a hard riding day in the mountains, keep the RPM's up and break it in again. That writer claimed it cured his bikes thirst! )
    Bob
    '12 R1200RT
