Results 1 to 15 of 25
Thread: Restoration Photos and Progress 1932 R4 Series 1
    Registered User vechbmw's Avatar
    Nov 2003
    Sturgis, MS
    Guys,
    This is some progress photos of my newest project, a 1932 R4 series 1.
    It is a 400cc single, with a three speed hand shift gearbox. I'm lucky in the fact that the original steering head ID plate was on the frame, and the number stamped in the ID plate, and frame, and engine all match. The bike has a lot of problems, needless to say. It was involved in a wreak sometime in it's 80 year old past, and the front forks were bent, and the frame is tweaked. I just now have the front end repaired. (which involved removing rivets, straightening the lower triple plate, and installing new rivets) I had to make all new pivot bushings and shafts for those tiny front swing arms. I have gone through, and finished, the gearbox and final drive, and drive shaft, so far. Now that I have a straight front end, I have to determine where the main frame is tweaked. But before I can have a good reference, I have to have two laced true wheels. And, of course, the wheels are not only WAY out of true, there are broken spokes, and naturally I will have to have spokes made, since they are not available. And the list goes on and on... Another year or so, and I may have it totally restored and back on the road.
    Nov 2003
    Sturgis, MS
    More Progress
    I am finally beginning the re assembly of the R4. I have most of the painted parts back from the painter. The frame and front end have been straightened.
    I have the lower end of the engine finished, but I am still waiting for the lifters to arrive, after their rebuild, and I am waiting for the lifter towers to arrive after being nickel plated. (Chrome plating was not used until the mid 1930's and on this bike, all the bright work is plated, polished nickel) The head is merely sitting on top the cylinder for the photo.
    The lovely, but primitive stamped, riveted steel front forks are installed in the frame, with new, modern tapered steering head bearings. Next step is to install the cantilever leaf spring and it's related suspension parts. Then the headlight bucket and install the cloth insulated wiring harness that I made last month.
    The transmission and final drive are also finished, and I plan on installing the transmission this evening. More photos will follow..
    Nov 2003
    Sturgis, MS
    R4 another progress photo
    Here is the latest photo. More to follow as it goes together.
    In this shot, you can see the gearbox is now installed. Notice the weird cross connection on the back of the output shaft. This is the hardy joint and instead of being a rubber disk, it is unlike any other BMW drive shaft joint. The end of the drive shaft, which as two cam like lobes, inserts into the cross, and two hardened pistons rest on the low sides of the lobes. Behind each hardened piston is two coil springs. There are two "pipe caps" for lack of a better description, that, when screwed into the cross, put pressure on the springs, which in turn puts pressure on the pistons. This mechanical arrangement acts to take up drive line shock, from acceleration and deceleration. There is also a polished, nickel plated sheet metal cover on the drive shaft, that covers this whole assembly, so it does not eat a hole in your ankle while riding. Very strange, but mechanically sound, way of getting the job done.
    Also in the photo, you can see the horn mounted on a bracket off the side of the 3 speed gearbox. The cylindrical object just below and in front of the horn is the generator, which is driven by the cam chain. Notice also that because the center line of the engine is very offset to the bike's right side, and with it, the transmission, the kick start lever is not on the bikes left, but rather on the bike's right side. This means standing on the wrong side of the bike to start it!
    What you cannot see in the photo is the throttle control on the right side of the handle bar. It has a mechanical lever that pulls a cable, that runs to the high low bean switch that is inside the headlight bucket. Also, there is a decompression lever. This cable operates a decompression cam in the valve cover, which lifts the exhaust valve and holds it open, so you can spin the engine up fast with the kick start lever. While the HEAVY flywheel keeps the engine spinning, one releases the compression lever, and then the bike will start. It is a blazing 13 hp and 400 cc, I have no idea how tough it will be to start, I have not gotten that far yet...
    More will follow after this weekend's work on the bike.......
    Sadly, it won't be ready for the national rally, but I will be there with several of my other bikes, so I'll see you at the Vintage Display. I will also be in the Vintage seminar, so come and listen if your interested.
    Nov 2003
    Sturgis, MS
    Another R4 progress photo
    I managed to get quite a bit done over last weekend. I spent two solid days working on it. From this view, you can see the final drive is installed, with the nickel plated sheet metal cover over the hardy joint on the drive shaft. I have completely wired the machine, with cloth wiring, covered by black braided sheathing, as used in the 1930's and 40's. I have added a brake light switch, (the original bikes had no tail light, and no brake light, only a reflector) and tail light wiring. I intend to use a Bosch JN-5 black cigar tail light on the top of the licence plate holder. I custom made all the cables, since none are available commercially. You can see, sort of hanging down, on the right hand control, the lever for the compression release. The odd brass cover on the final drive is a vented cover, that allows you access to the rear axle. This bike has NO wheel bearings in the rear wheel. The ring gear bearing acts as a axle bearing, and there is a frame mounted housing opposite the final drive, with a double row, self aligning ball bearing mounted in it. Yes, that means that this bike as a LIVE rear axle, that turns with the wheel! As I get further along, more photos will follow.
    Nov 2003
    Sturgis, MS
    Another progress photo R4
    This is the latest progress photo. The hand pin striping is finished on the frame, front end, and front fender. The front fender was hell to install. Very tight squeeze, and very tricky to get in place without scratching anything, but I managed.
    Nov 2003
    Sturgis, MS
    R4 documentation
    One added tidbit that was with the bike is the original German vehicle registration book, with the names, and dates and official government stamps for the bike, since 1932. This is the first page of the book. I understand that documentation such as this is very rare. The last entry of ownership is 1953 in Germany. This bike survived WW II in Germany, and was brought to the states in the late 1950's.
    The serial number of this machine is clearly visible. But what is so odd, is the date of 1931.
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    What a beautiful bike! Visually, I think these are my favorite...
    Looking forward to your next installment!
    Ken
    -Albert Eienstein
    Mar 2011
    Bloomfield Hills MI
    Wow! Where do you find these things? I have to say that I have endless amounts of respect and admiration for people that can do what you do with these bikes. Can't wait for more updates!
    Nov 2003
    Sturgis, MS
    RE: Where do you find these things?
    Quote Originally Posted by 166926 View Post
    Well, it's all quite random. I just luck out, when it comes to finding old BMW's. But, since I'm getting old (61) and have been a vintage enthusiast for the last 40 years and am in the restoration and vintage parts business, I do have a lot of contacts, so what can I say? I never buy anything sight unseen, and never overseas, since that is a good way to get burned. And, I always try and buy original condition, (no matter how bad) machines with matching numbers. Not "restored" bikes. No point in doing all that work and spending all that money unless it is a correct bike, as far as numbers go...
    Nov 2003
    Sturgis, MS
    progress as of July 13
    In this photo you can see that the leaf spring, and support bow, has been installed, and the brake backing plate is now bolted in place on the right side of the support bow. You can also see the that the front wheel stand is also installed. I finally managed to obtain a Framo leather seat top, and have it installed on the seat frame, and in turn have temporarily mounted it on the bike.
    What is not in the photo, is the petcock for this machine. Unlike later petcocks used on BMW's, this is a brass, simple on/off petcock, that is of the English type used in the era. It has a sliding plate, with flat "buttons" on each end of the sliding plate.
    One pushes the slide into the body, to turn the fuel off, or on. I had to cut cork disks out, and make a new "button" on the lathe to replace the one that was missing. I had to solder it to the end of the flat slide, using 95/5 solder, to repair this original petcock. I believe it will work, but I won't know for sure, until I get the tank back from the painter, and put gas in it.
    On another subject, the gas tank originally had a filter/gas gauge, made out of brass, that dropped into the tank, under the cap. It is missing, so I am going to make a new one out of brass, and fine mesh brass screen. I'll post a photo of it when I'm done.
    Nov 2003
    Sturgis, MS
    The R4 fuel strainer/gas gauge
    Here is a straight down view of the duplicate brass fuel gauge/ fuel strainer that I made last weekend. I made both the top flange and bottom flange out of brass on the lathe. I made the supporting spiral piece of of flat brass stock, and formed it around an old R51/3 fork tube, using a dead blow hammer. I cut out and bent the fuel tabs out of flat stock and stamped the liter numbers in each one.
    Nov 2003
    Sturgis, MS
    R4 photo as of July 16th
    In this photo you can see that the front wheel is now in place, along with the battery and the tool box (which is directly behind the battery). The horn is quite visible in this photo. I checked out the wiring to make sure everything functioned correctly, after installing the battery. All is well. The brake light, tail light, high beam low beam and horn all do their "thing" as they should. I have a gen indicator lamp also, but I can't check to see if it charges, and at the correct rate, until I have a header pipe and muffler and can start it. The next thing, (after I return from the National Rally) is to lace and true the rear wheel and mount the rear tire.
    I will see you at the Vintage Display if you are going to the National.
    I'm bringing a 1936 R17, a 1928 R52, a 1941 R12 a 1939 R23 and a 1942 R75 with the side car. See you there!
    Sep 2009
    SW, MO
    Coming along nicely! I really like your filter/guage setup-quite inovative.
    That's going to be a beautiful machine when it's finished!
    Ken
    -Albert Eienstein
    Nov 2003
    Sturgis, MS
    R4 - fitting the exhast system
    Needless to say, as with most reproduction prewar parts, they never fit correctly.
    I bought a header pipe out of Poland. This is the second one I ordered, since the first one that came out of Germany was completely wrong, and was for an R35, and wasn't even close to fitting. It was so far off it could not be modified.
    This new pipe, as you can see, did not fit either. I had to modify it by cutting the pipe in two, half way down from the head, to the second curve. You can see the welding done to it, in the photo. Since the pipe was too short, I took a scrap piece of steel pipe, put it in the lathe, and turned down the outside diameter until it matched the diameter of the header. I then turned each end down until it would just barely slip into the inside of the header. I then put it all back on the bike, and adjusted every thing until the header cleared the front fender, and the frame, and would tuck in fairly close to the driver foot peg mount. I had to heat the header, and "dent" it in, just a bit, so it would clear the foot peg mounting nut. Then, I had to cut off about 2 inches of the end of the header, since it was impossible to shove the muffler onto the header far enough forward, so the center stand arm would come out in the "dent" on the bottom of the muffler, when the center stand was retracted. After I got everything fitted as described, I shielded the painted parts of the frame and fender, and tack welded both parts of the header pipe to the "extension" that I had made on the lathe.
    After grinding and sanding the weld, I boxed up the modified header, and set it off to be bright nickel plated. Now I must sit back and wait for a month or so, until I get the header back. After I get the header back, I'll be able to start this engine for the first time, in at least 59 years..........
    For some reason the visual diameter of that header pipe looks big! Maybe it's sized for the R4...my R25/2 pipe isn't that big. It even seems bigger than those used on the /5-on bikes.
