Results 1 to 14 of 14
Thread: R80RT Tire Mis-matched
    Jul 2006
    Traverse City, MI
    Greetings,
    Acquiring an R80RT (87) mounted on the front is a Michelin Activ on the rear is a Michelin Macadam. Is there any concern handling or otherwise in the mixed set? The tires have more than adequate life left.
    73516
    Administrator 20774's Avatar
    They are both bias ply tires...shouldn't be a problem. I've never had the same manufacturer tire on the front and rear at the same time on my /7. It's not a problem as long as the tire is the right size for the application and you're not using the tire for something it wasn't meant for. Ride on...
    Apr 2012
    Agreed. I have been running different tires for a while, works just fine.
    Mar 2008
    Lake Saint Louis, MO
    I think the only people that tell you that it is not ok, are the folks at the dealership trying to sell you two tires. I have done it for years.
    Grammarian no, Rider yes ISAMEMON's Avatar
    Jun 2006
    Kings Valley Oregon
    so reading this, I often wondered about metzler and radials
    for example a combo that is/was often popular on the BMW bikes is the metzler lasertec in the front and a mtzler ME880 marathon on the rear
    however, the laswertec is listed as a bias ply and the me 880 a radial ply
    Are you sure about the ME880 tire for an Airhead? The sizes are not at all correct for the bike. One of BMWs latest service bulletins shows Metzeler tires ME55 for the rear, not anything like the ME880.
    Generally, I've heard to not mix bias ply tires and radial tires.
    Nick Kennedy
    Nov 2011
    Telluride Colorado
    73516
    Your lucky to start out with 2 good tires!
    Make sure you put enough air in them, modern tires need more PSI than what is posted on the sticker on the bike.
    You may want to start with 32-34 in the front and 34-37 in the back; play with the air pressures, and see how it works for you.
    Nick Kennedy
    Jun 2006
    Kings Valley Oregon
    Ill have to hunt for a link , I thought it was common and on the old airheads you had to use a spacer on the axel for the tire to clear, it was a 120x?
    that is what was on my old airhead, a 78. that combo
    Fenwick, Ontario Canada
    Yes, you can run a 120/90 18 rear tire but you will have to deflate it to install as well as use a spacer.
    This can be a giant pita on a trip if you get a flat.
    Proper size is a 4:00 x 18
    You can run a 110/90 18 but you may have centerstand issues because of the metric profile, these are what I run.
    Knights of the Roundel #333
    1977 R100RS with 516,000 miles
    Quote Originally Posted by Isamemon View Post
    Was it the ME88? Snowbum mentions that tire in Section 5 on this page:
    http://bmwmotorcycletech.info/section5.htm
    Old man in the mountains osbornk's Avatar
    Feb 2006
    Marion VA-In the middle of some of the best riding in the country.
    Quote Originally Posted by nickrides View Post
    73516
    Nick Kennedy
    My 86 R80RT calls for 36 in the front and 42 in the rear. I have always run that pressure and it has worked well for me. I generally ride crooked mountain roads and the sides get most of the wear.
    'You can say what you want about the South, but I almost never hear of anyone wanting to retire to the North.
    Black 86 R80RT Brown 03 R1200CLC
    You must go by the Tire manufacturers reccomendation not the bike.
    Can't stress this enough!
    Jun 2006
    Kings Valley Oregon
    correction, it was a me 88 not an 880
    Apr 2012
    Quote Originally Posted by osbornk View Post
    Yeah, go ahead, rub it in for us who live in the land of straight as far as the eye can see!
