Results 1 to 2 of 2
Thread: Garmin Zumo 665/Road Tech Zumo problem?
    2009 R1200RT beemeup's Avatar
    Portland, Maine
    One of the things that I've encountered is that after updating my maps or adding maps to my Zumo 665, I now have a problem where my Zumo says it can't find my MP3 music files part of the time. I have to turn it on and off a few times in order for it to finally find my music. I did a reset as was recommended on the Zumo forums but that hasn't helped. Has anyone else out there had this problem and found a solution to it? Please share, I'd love to correct this annoying problem with my unit.
    Thanks!
    Jan 2008
    So Cal
    Had the same problem on my 660. If I turn it off, remove the SD card, insert again and turn back on, it seems to fix the problem. Hopefully there will be a fix next software up-date.
