Results 1 to 11 of 11
Thread: Lester Mags pre load
    Arctic Art
    Oct 2010
    Manley Hot Springs Alaska
    1983 R100S W/Lester mags.How do you get the 2" chrome hub off it has 4 holes, looks like it maybe a spin off.I want to replace internal parts as the preload seems too tight and it is advised to install BMW guts.Wheel is about right w/ 10 lbs torque on axle nut. Any advice and direction would be appreciated.
    Picture? Hole spacing? The old /2 bikes had a hub nut that has four holes...I bought a hub nut removal tool from Cycleworks...worked excellent. They list a tool for the /6/7 bikes, but no mention of Lester wheels.
    Arctic Art
    Oct 2010
    Hub OD 55mm,Hub ID 36mm,Hole spacing center to center,opposing holes 44mm, 4 holes,5mm ea.So,these would have to come off to get 40mm bearing races in.
    As it turns out, that hole spacing is exactly what my /2 hub nut removal tool is. I'd check with Cycleworks...what's the cost of a plane ticket to Alaska...
    Happy to Be Here amiles's Avatar
    Jul 2003
    Murrells Inlet, S. C.
    The Lesters that you have were PROBABLY set up for the /6 and similar configuration. The deal was that you would buy the Lesters, Transfer your bearings & other hardware (including the caps you speak of).
    I believe that the 83 model has the newer style grease seal etc. Check the /6 parts diagram & see if that isn't what you have. the small cover with 5 bolts on the rear wheel bearing is also indicitive of a /6 type wheel.
    Harbor freight used to have an adjustable pin spanner & probably still does.
    May 2007
    Art,
    You can make your own tool. 1/2 square key stock 2 1/2 inch long or so. Drill two 5mm (7/32 inch) holes spaced to match the holes at 180 degrees. Insert two 5mm x 20 mm lg bolts and nuts. Use a 1/2 inch open end to turn the tool.
    Worked for me
    Dave
    BMW R 1150 RT Kawasaki KLR 650
    BMW R 75/6 Honda C70 Passport
    BMW R 100 RT Under Construction
    DoktorT
    Spokane
    Why not just work down the spacer with abrasive on plate glass to thin it a bit and increase the preload at spec torque??
    May 2012
    VA
    The expect the hub spins off. The 4 holes are for a pin wrench. I have used a strap wrench before on my 78 wheel hubs and it works fine - lefty loosy. The hub was not very tight.
    The brake disk may need to be removed when using a strap wrench. If so, I highly recommend marking all the bolts (and nuts) relative to the hub and the disk relative to the hub with a sharpie marker. The sharpie ink will wear off or can be removed with rubbing alcohol. Alternately, you can get a pin wrench from Harbor Freight, Amazon, etc. Good Luck!
    Stan
    AH# 13238
    Arctic Art
    Oct 2010
    Quote Originally Posted by doktortim View Post
    I am under the imperssion that if my wheel bearings gets too tight with a less than the spec. torque than my spacer set is too loose and I need to add a shim. Is this correct or am I bass akwards.
    DoktorT
    Spokane
    Quote Originally Posted by 140008 View Post
    A thinner shim will require more torque to obtain proper preload.
    On second thought, I am now confused myself. Best go review what Snowbum has to say before going further.
    Arctic Art
    Oct 2010
    Cool
    I did read on the Snowbum site until I understood.Quote:"If you use a wider spacer,the preload DEcreases,as the bearings are now "held out" farther from the bearing shells." So,if my preload is too tight I want to add a shim to hold the bearing races further away from the shells so that I can increase the torque on the axle to the correct spec,without the bearings being too tight. Wheel preload too tight add a shim.
