Results 1 to 8 of 8
Thread: Givi E 55 topcase help
    On the water. sibud's Avatar
    Feb 2006
    Southern Illinois
    Question Givi E 55 topcase help
    The handle is supposed to pop up when the key is turned to the right. But mine doesn't. If I press the handle it opens the case.
    But I have no way to carry it once off the bike.
    Any suggestions?
    Bud Meade W9BUD IBA 44018 MOA Lifetime Member
    Ride Well
    Ride Often
    Ride to
    Sheboygan, WI
    Cool
    That's a head scratcher.
    I just went out to the garage and turned the key to the right - handle popped out - then pressed the big black button and my Givi 55 released from its mount, handle at the ready.
    Good luck with this problem.
    Kevin Greenwald - Touring Tips Editor
    Nationally Certified Law Enforcement Motor Officer (Ret.)
    MSF RiderCoach # 121656 (BRC,SBRC,IS,IME,SMARTrainer,THE REF Staff)
    Iron Butt Association Member # 34281
    Rocky Bow BMW Riders #197 bogthebasher's Avatar
    Calgary AB
    I have two of these (2 bikes) and one of them did this at first I kept working it over and over and finally it popped once although barely. It still won't always open in cold weather - might be a fit/finish thing with yours kind of like mine. Good luck.
    Ken
    [2008 R1200RT (Biarritz Blue) - Mine]
    [2007 R1200RT (Sand Biege) - Hers]
    Feb 2006
    Southern Illinois
    Hi Kevin,
    Wanna trade?????
    Ride Well
    Ride Often
    Ride to
    Feb 2006
    Southern Illinois
    Quote Originally Posted by bogthebasher View Post
    Thanks Ken. It was off the bike when I bought it as there was also a Givi Traffic bag attached to the mount. I mounted the 55 on the bike and closed the handle. That's when I found out it wouldn't pop back out.
    Hopefully there is a solution?
    Ride Well
    Ride Often
    Ride to
    Moondog moondog's Avatar
    Pooler, Ga. (Savannah area)
    There maybe something wrapped up in the inside mechanism, piece of clothes, etc. I have to be careful there is nothing interfering with the latch inside before closing it
    "Badges? We don't need no stinking badges"!
    1983 R100RT (and broke my leg)
    1996 K1100RS-SE
    Feb 2006
    Southern Illinois
    Quote Originally Posted by moondog View Post
    Thanks for the suggestion.
    It opens and closes just fine with no problems or binding. What it will not do is release the handle so that I can carry the bag by the handle.
    Ride Well
    Ride Often
    Ride to
    Feb 2006
    Southern Illinois
    So I took it apart today.
    It seems that it will open if I put a lot of pressure on the key after turning it all the way to the right where it feels like it shouldn't go any more.
    Didn't seem to be any way to adjust it to open sooner.
    But at leats it will open.
    Ride Well
    Ride Often
    Ride to
