Results 1 to 5 of 5
Thread: Converting front signal lights to running lights on 91 K75
    Elwood 169347's Avatar
    Canadian Prairie
    I have imported my 91 K75 from the US to Canada and in order to register the bike I need to convert the front signal flashers to running lights/flashers.
    Has anyone done this type of conversion and if so can you let me know how you went about it? The two approaches I was considering were:
    1) Customizing the front signal bulb receptacles to accept dual element bulbs. I could then slave power from the headlight circuit for the running light element. The problem I have is that the signal flasher plastic mounting hardware is not easy to change. Did any future K bikes use the same flasher housing with dual element bulbs?
    2) Changing the flashers to work as "normally on" rather than "normally off" lights. This is made difficult by the integrated relay flasher unit. If the signal flashers used standard relays I might be able to swap the relay to invert the logic. However, with the integrated unit it becomes tricky.
    I'm leaning toward method #1, but would love to hear any suggestions.
    Quote Originally Posted by 169347 View Post
    Contact RunNLites - he has a socket that replaces the standard socket and take a dual filament bulb.
    The problem with always on flashers - is how do you see them flashing if they're always on? It would require a way to drop the voltage to them in the non-off running-light mode, and then up the voltage when the light is working as a flasher plus isolate the lights from one another... Not all that easy to do - would require relays and some fairly substantial (in Wattage) resistors. The RunNLite socket is the way to go (I had them on my K75S and they worked fine.
    A big +1 for RunNLites. Ridiculously easy install, quality materials, decent price.
    Look here:
    http://www.run-n-lites.com/AppGuide-Run-n-lites.asp
    Assuming you have a standard I believe you would want the Type-2 front kit. Might as well pick up the K-Tail-2 while you are at it, a nice thing to have and adds volumes of light at the rear.
    Ted
    1994 K75RT
    Moto Pages
    Canadian Prairie
    Thanks for the recommendation! The Run-N-Lite kit is exactly what I was looking for.
    Tom Mieczkowski mieczkow's Avatar
    Mar 2006
    St Petersburg, FL
    Ditto
    Got them on my K75 and they are great.....
    Tom Mieczkowski
    1987 K75S
