Results 1 to 6 of 6
Thread: K75S Rear turn signal replacement?
    Aug 2006
    Someone dropped something on my K75S when it was covered and when I uncovered the bike I found that the right rear turn signal was broken off. What parts do I need to replace the turn signal? I am not really knowledgeable, so I really couldn't tell by looking at it whether the entire plastic assembly (holding both turn signals) that goes under the seat has to be replaced or if just the small arm that holds the right-hand light can simply be changed out. The signal itself still works so the wiring appears to be fine. Any assistance with part numbers and possible sources of supply would be appreciated.
    Gordy Olson
    1993 K75S
    Gordy - not sure which part fell off. The turnsignals are seperate items that simply bolt in from the inside of the rear section. Beemerboneyard would be the first place I'd look for a reasonably priced replacement. If you want new - any dealer can get one for you. There is a left and right side (the mount to the rear plastic is different.)
    Dum vivimus vivamus TED's Avatar
    There are several excellent places to buy good, used parts for older K bikes. Here are some along with Beemerboneyard I have used and like:
    http://www.re-psycle.com/
    Out of Ohio, has good prices and great customer service
    http://www.kbikeparts.com/
    This is Drake's business, he is active on several Kbike communities and knows these bikes well enough to assemble one in his sleep, in the dark. Great selection, prices, usually my go to place.
    Ted
    1994 K75RT
    Moto Pages
    Aug 2006
    Ted: Many thanks for the prompt reply. Beemer Boneyard didn't have one at the moment, so I will just order one from my dealer. Hopefully, should be "case closed"! Gordy
    Jul 2007
    Evansville, WI
    Just an addition, that the rear signals on the 75S are the same as any other K75, I think the K100 line also used that signal. The front of course is different on an S
    87 K75S, bought new, now sold
    13 C650GT
    MOA 44606
    Aug 2006
    Case successfully closed! Thanks for all the good advice......
