Hi everyone, I just have a few stupid questions and I would appreciate some help please. My bike is leaking oil from the front boot on the final drive. I removed the swing arm and there was a lot of dirty oil coming out of the housing, my clymer manual states that the drive shaft has it own oil supply ? I assumed it was the rear output seal on the tranny. It does show signs of clean transmission oil on the outside.
How much oil is suppose to be in the drive shaft housing and where do I put it in??
I then dicided to pull the tranny to lube the splines, btw they were bone dry. Could this be my down shifting problem that I havent mentioned yet?
My other question is about the circlip in the tranny, is there a way to find out if it has it in or not without disassembling the tranny?
I tried to search this and other forums without much luck so any help would be appreciated. I would also like to see some picss of a flange holding tool (homemade) if anyone has one, please.
Thanks.
