Any chance those R100 cylinders were post '81 with Nikasil coating on them? That might be why there was this type of reaction. If that's the case, then the cylinders are probably toast. There may be companies who can reapply the Nikasil coating....might be expensive.
. That year BMW was the end of the iron lungs and '79 brought the new non bore type ones, nikasil. You can switch over, buying new style but why? The older ones are quite servicable and I think you need the bore job. My last bore at 104000m, first over pistons and now at 380000m, same ones still pumping great ,all in iron sleeves
