Leaking master cylinder 84R100RT
My 1984 R100RT is leaking from the bottom of the handle bar mounted master cylinder. I disassembled the master cylinder and replaced the O ring between the base of the master cylinder and the reservoir. I used the old piston assembly when I put everything back together. Are there any other defective parts that could cause this leak.
Administrator
I found this thread in the past...maybe something to be learned here:
http://www.bmwmoa.org/forum/showthread.php?t=59042&
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
