ok, just did a complet service on the bike, i did a brake flush and know the abs lights or flashing, how do i reset the system
Did you start it up and took it for a spin and the lights are still flashing? It is a different system than mine so I can't help beyond that, unless your battery is low and possibly caused a relay to fuse.
Jim Douglas '00 K1200RS >129,000 my primary bike again, Kaw 650R track bike
Gone: '09 K1300S SOLD @ 22,232mi, '93 K1100RS traded @ 78,000, '85 K100RS sold @ 44,000
http://www.seagullbb.com/
The rear brake reservior is sensitive to fluid level, if it's a touch low you will get that fault.
I found out way the abs light was on, the rear brake tank has two side, the one one the inside of the bike was low.
