Results 1 to 13 of 13
Thread: A how to Build your own Rear Mud flap
    PRAY BEFORE RIDING roadcrave's Avatar
    Jul 2004
    ninemilefalls,wash
    I was disgusted with all the gravel - tar and mud the rear tire pics up here in the NW so I did some research and came up with this step by step to add protection to your rear swing arm/shock/dog leg from getting trashed every time you ride. Here is what you need
    1. urethane rubber Ebay / POLYURETHANE/URETHANE SHEET 1/8" X 9 3/4" X 14" 80/85 Black Part#102
    2. rivots aluminum 1/8 x 3/16
    3. sheet metal sheers
    4. rivot gun
    5. washers
    Remove your factory rear mud gaurd, place on the table and scribe as wide as you wish I went 1/2 wider than the wheel and 1 inch lower than the center stand in the up position, then cut and pre drill your holes, .\see pic
    Pop rivot the gaurd to the foward part of the factory gaurd using backup washers
    Jul 2004
    ninemilefalls,wash
    more pics oc rivot area
    This looks like a front mudflap for the rear wheel!
    Jul 2004
    ninemilefalls,wash
    What are you implying??
    Registered User Meese's Avatar
    Feb 2011
    Looks great. Cheap, and quite functional in solving a known problem for those of us who ride year-round in all weather. I just ordered some of that urethane sheet for myself.
    Thanks for posting the how-to.
    Ken
    SoCal
    '12 Mineral Silver Metallic K16GTLD
    IBA# 366, MOA# 111996, SCMA# 24032
    Aug 2007
    Hi Roadcrave: Is the urethane sheeting material you used pretty rigid or is it flexible? I had given thought to purchasing an OEM rear fender extension and mounting it on the front of the rear fender the way you did. Thanks, Rick H.
    Jul 2004
    ninemilefalls,wash
    This produst is 1/8 inch thick and very flexible, the legnth is what you will need, ...... matthew
    Registered User jamesgoodchild's Avatar
    Apr 2012
    Does the mudflap drag on the wheel at high speeds since the urethane is quite flexible?
    Jul 2004
    ninemilefalls,wash
    Yes at highspeeds 130mph, its ureathan and hardly get hurts , But im re designing the shape and adding a couple gromments to hold it forward,easy task though ill keep you all informed as soon as i get a chance...matthew
    Jul 2004
    ninemilefalls,wash
    Modification, Stainless Steel to curve the Flap keeps it off the wheel
    Jul 2004
    ninemilefalls,wash
    side pic
    Jul 2004
    ninemilefalls,wash
    Chopped 4 inches off of it today
    Jul 2004
    ninemilefalls,wash
    3000 miles no issues, fyi
