I'm trying to check all splines by myself and get the machine going again.
1. What grease is recommended for the swing arm bearings?
2. What grease is recommended for the drive shaft universal joint?
3. I'm going to use a 50/50 mix of Honda moly 60 and Wurth 3000
for the splines as I believe Mr. Glaves recommended.
4. I read on this forum about the longevity of K100 clutches. If I separate
the transmission from the engine and do not touch the clutch, do I need
the clutch alignment tool to put it back together?
5. What do you recommend for the cast aluminum surface that has
the coating breakdown with the white dust?
6. Can you tell me of a charging system status indicator and where I can
purchase?
7. What is a good wet battery charger product?
8. On re-assembly of fasteners which is better; to assemble clean and dry or
to assemble clean and with the light thread lock? Of course to the proper
torque.
9. Any recommendation on average price tires with good performance in wet
conditions?
Thank you for your assistance. Bruce
