Results 1 to 8 of 8
Thread: Battery for 1995 K75 standard (no letters)
    Registered kobukan's Avatar
    Jun 2008
    Saco, ME
    Quote Originally Posted by atlbmw View Post
    . . . has anyone put the pc925L in? Does it fit? Did you need special brackets? Is it overkill? (The specs show that it's about .25" higher than the 51814 that I have in there)
    I'm probably a little late to help you, but I can answer your question. I put an Odyssey PC925L in my K75 about a year ago. It fits fine without any special brackets, but it is slightly taller and I had to put a little rubber spacer above the coolant reservoir to keep the reservoir snug. Yes, the PC925L is probably overkill and it was expensive, but it's got some serious cranking power.
    Dean
    '04 R1150RT, '97 1100GS, '99 DR350, '02 DR650, '03 DR650
    Registered User PHMARVIN's Avatar
    El Paso, TX
    In the past, i have used BMW batteries in my K-bikes (K1100LT's and K75's). The slosh ones (have to check and add water periodically) generally lasted about 3 years before taking a dump. The last one I got was a BMW Exide maintenance free battery. It lasted about 2 years to the day, then wouldn't even turn on the instrument lights. So I've written off BMW Exide and install whatever I can find which fits. The most recent (3 years and counting) is Batteries Plus maintenance free.
    Ride Safe,
    Phil Marvin - El Paso, TX
    '94 K75A/3
    '95 K75RTP
    Florence County South Carolina
    I bought a Odyssey PC680 directly from Odyssey for $124.00 shipped. I had it in 3 days...
    AKA SNAPGADGET
    Belton Tx
    What is the AH rating on the 680? I think I need a 30AH to keep the ABS on my 91 K75RT happy. The 4yr old Westco is cranking a little slow and dropping to 9.7V on first start now.
    Ron
    91 K75RT
    Dances With Sheep GREGFEELER's Avatar
    Boise, ID
    Quote Originally Posted by roncooper View Post
    The owners manual for my '93 K75S specifies a 25Ah battery. However, both the Westco and Odyssey sites specify their smaller batteries for this bike: 12V20P (20Ah) and PC680 (16Ah) respectively. However, both companies recommend their larger batteries (12V30 (30Ah) and PC925 (28Ah)) for a K75RT. I don't really get that unless it's a legacy specification from BMW.
    However, my 2003 K1200RS, later K1100's, and just about all oilheads only have room for the smaller PC680 sized battery. I have a PC680 in my K75S and my K1200RS and it cranks them over just fine in 20 degree temps with 15-50w oil. I figure if the PC680 sized battery is big enough to run all the electrical load on the K1200RS (including the electrically powered whizzy brakes) it will do just fine in any K75. Also, the PC680 is 10.6lbs lighter than the PC925.
    Finally, I've had three Westco batteries die suddenly on me. By that I mean they are less than three years old (one was only 8 mo. old), are working apparently perfectly, and then won't turn the bike over after being shut off for five minutes, or are stone dead after sitting over night. I suspect the ones I've had broke and shorted internally while riding, so would go dead very quickly once the bike is off. A suddenly dead battery is something that can be a lot more than inconvenient, so I'm switching completely to Odyssey. They have a reputation for long life and NOT sudden death. I hope so. YMMV
    Greg Feeler
    BMW MOA President, Ambassador, & cat herder
    1972 R75/5, 1990 K75, 1990 K1, 1992 K75S, 2003 K1200RS
    Quote Originally Posted by kgadley01 View Post
    I hope that they thanked you for the $20 tip.
    Not battery related, but relevant nonetheless. Shopping around does pay dividends. I recently bought a small duct fan designed to boost flow in 4" furnace ducting. I found several vendors that sold the same model by the same manufacturer. Prices for these identical fans ranged from $14 to $69 depending on the vendor.
    SW Ohio
    I've had good luck with Westco in my K75 (going on 7 years and still strong) Just saw this at BBY, $86+shipping http://www.beemerboneyard.com/westco12v20p.html
    K75S
    Original litter
    Original owner
    2012 Ural Gear Up
