Results 1 to 4 of 4
Thread: Drive shaft twist
    Kurt Snyder
    Dec 2004
    Vermont
    Drive shaft twist
    I removed the drive shaft from my 95 R1100RSL and discovered the shaft had twisted at the rubber bond sometime this year. I had paint marks on the shaft for phasing during assembly which are now 45 or 225 degrees from the initial position. The current shaft has about 50000 miles. I was planning on sending it to Bruno for u-joint replacement because the u-joint seals had been leaking. I just e-mailed Bruno asking if the bond is a repairable item and I am waiting to hear from him. Does anybody have any experience with the driveshaft slipping at the rubber bond? Does the shaft tolerate some slip at the bond? Would I be on borrowed time if I set the phasing and continued to use the shaft?
    Thanks,
    Kurt Snyder
    Northfield VT
    Sep 2006
    Steve Henson
    EX-Prez SABMWRA MOA Club#62/ current forum moderator
    Kurt Snyder
    Dec 2004
    Vermont
    Not the same shaft. This was a new replacement for that one.
    Sep 2006
    Yikes then! I mark the shafts and have not seen one do this yet. I recall reading about one is why I did a search and found the 2007 posting.
    You doing burnouts to load the driveshaft?
    Steve Henson
