Results 1 to 15 of 19
Thread: Rear Main Oil Seal Removal ~
    John D'oh
    Aug 2006
    Close to Fort Worth Texas
    I believe that folks are making more of a job out of this than is necessary. I had planned to disassemble an engine for some parts and finally got a chance to photograph the technique. Here in photographs is how I remove a rear main oil seal from the engine case of, in this case, a 1978 R100/7. Notice that the bottom lip of the seal is black from oil leaking past it and, the outside edge of the seal is even with the engine case. The seal is an original factory plastic seal correct for 1978 which has probably not been replaced before this.
    First photo is the seal in place: Note oil on lip and seal position in case.
    John D'oh
    John D'oh
    Aug 2006
    Special Tool...installed~
    John D'oh
    John D'oh
    Aug 2006
    Give special tool a twist~
    John D'oh
    John D'oh
    Aug 2006
    Grip tight and twist hard left or right~
    John D'oh
    John D'oh
    Aug 2006
    Job is done. Install new rear main seal.
    John D'oh
    Registered User donbmw's Avatar
    Feb 2004
    Monroe La.
    Quote Originally Posted by s09rwmb View Post
    I hope you block the crackshaft before doing this.
    John D'oh
    Aug 2006
    So, 'blocking the crank' does NOT go without saying so...
    Quote Originally Posted by donbmw View Post
    I did not block the crank shaft. The empty engine block and some of the parts are currently sitting in my SK machine. As illustrated there is no prying done to release the seal - its diameter is reduced and it's pulled from the pocket 'almost effortlessly' which was exactly the point of this post. Putting a new seal in or the fly wheel back on is quite another issue especially for anyone doing this job for the first and only time they are likely to need it done. Block the crank shaft as necessary....
    Note that sometimes you must peal a bit of the plastic away to get to the metal core of the seal...
    michaelc
    Very interesting. I'm pulling the main rear seal on my bike this coming weekend, as it happens. This will help a lot. Thanks for the excellent pictures.
    Feb 2004
    Monroe La.
    blocking the crank
    I have changed the seal on my R90 back around 1987 and even with the BMW manual I have didnot know at that time I need to block the crack. Just got lucky that I didnot have any problems then.
    Jun 2007
    Minneapolis, MN
    Matt Parkhouse's column in current issue describes this subject.
    John D'oh
    Aug 2006
    Quote Originally Posted by kentuvman View Post
    Matt Parkhouse's column [in the Owners News] current issue describes this procedure.
    Nope, sorry - Matt uses a slide hammer and occasionally a punch to remove the seal. This method uses pliers.
    Jun 2008
    Thanks for posting this. I'm performing the same repair on my '72 R50/5. I was wondering what the ring is that's mounted on the two pins behind the seal. I see one in your picture and I was wondering what this is and it's purpose.
    Thanks!
    Registered User robertklee's Avatar
    Mar 2006
    Tennessee
    Took my /5 apart to replace rear main seal and after inspection realized it was transmission seal that was leaking. So you might have one of those in hand just in case.
    RKL
    "Leave the gun. Take the cannoli."
    Jan 2011
    kentucky
    block
    how do you block crank
    you can buy a tool to thread into the frnt of the crank, or use rags or something similar between the front cover and crank. i used pieces of bicycle inner tube taped in position.
