Looked in Clymers...Didn't find it. Want to know before I go tearing s*%t up!
Thanks for any help.
Will
Will
What's broken and what were you thinking of doing? I can't think of many repairs to a speedo cable. Usually it involves buying a new one.
Speedo and odometer quit. Need to find out how cable releases from trans. to see if that's the problem.
Thanks Will
The bolt that holds your neg battery cable to the trani.......right side.....also holds your cable in place.....remove the bolt........pull back the rubber boot......your cable will then be free to pull from the trani......
1992 R100GS (ZED)
1981 R100/t
No Rules Photography at http://brittrunyon.com/
My riding videos @ http://vimeo.com/user2721333/videos
... and don't forget to be GENTLE when you re-install that bolt, it's easy to strip out the case ... also note that the bolt is hollow (it doubles as a vent) so you might want to make sure it's clear.
Lew Morris
1973 R75/5 - original owner
Lew -
That's an unusual orientation of that bolt...normally it comes in from the left in your picture. What's the situation with yours? Or is it just hanging out in the air because it had been detached?
Really... .. it's the way it's always been. There is no hole on the "left" face of the speedo boss. In fact, until this moment, I never even noticed that there was a "flat" on the left side of that boss.
Curious. My bike is a /5.
other /5s...
Lew Morris
Ah-Hahhhh!! It's a /6 and beyond-ism!!!
Lew Morris
Thanks, Lew...I guess I never figured that. But now that I checked, my '69 R69S has the side-facing bolt, although the battery ground cable is routed to a different bolt on the back of the transmission. Here's a pic:
But we digress!!
Hey, thanks everybody....You see, I would have had it all a**-up!
I make my living beating pieces of hardwood together.
The GS neg. is located aft of the trans. Will pull the cable out as soon as I take
the tank off and disconnect the headlight cover. Let's hope it's the cable!
You sure know how to make a guy question a decision......Looked and looked for a /5 for maybe two years, then fell onto my GS and settled for it. All those /5 photos of bolt location made me think about trading for a /5!!
Thanks again Will
Always good practice to disconnect the battery ground FIRST.Will pull the cable out as soon as I take
You never know what little surprise will occur when you start taking things apart.
Lew Morris
Always trying to economize ... gotta lower that parts-count.my '69 R69S has the side-facing bolt, although the battery ground cable is routed to a different bolt on the back of the transmission.![]()
Lew Morris
Best place to find a speedo cable?
Thanks again
Just about anywhere...
Hucky's,
MAXBMW,
BenchMark Works
Ted Porter's Beemer Shop
... and others.
Disclaimer - I have no affiliation with any of the above.
Lew Morris
