I have recently notice that I get a slight slopping of the clutch in 5th and sometime in 4th when I twist the throttle significantly ie on a hill.
Shifting does not seem to be problematic and I do not getting any chattering when I start off. No problem at high rpm.
Cannot make it slip in other gears or when starting.
No oil around case connection and no oil dripping
I searched around for Forum notes and also to IBMWR and found references to clutch adjustment. Mine has had to be adjusted at the grip to a full in position so I am thinking that the new cable that I have already threaded through should be attached and adjusted.
So, the question is: could a stretched cable with a maxed adjustment create a slipping to occur or might leaking rear main seal be more likely? - Bob
- Bob
