Results 1 to 8 of 8
Thread: (1987 K100RS) Bar end weights with heated grips
    Nov 2009
    Vancouver
    I recently purchased a set of Thorttlemeister bar end weights hoping to quell the vibration in my handlebars. Unfortunately, I just found out that unless I had factory bar end weights already, fitting these weights on will not be an easy task. Too bad, as I was looking forward to the double duty they would have provided.
    Are there any other options for bar end weights on a K100RS with heated grips?
    Dum vivimus vivamus TED's Avatar
    I used the K100 standard heated grip kit with my K75S to take some weight off my wrists, along with new ope end grips/switch and wiring it came with a new bar and bar end weights that used anchors inserted into the bar. If I remember right the Throttlemeister I bought worked just fine with it. I did get a question occasionally regarding why my K75 had bar end weights
    Here is the schema from Max's:
    Ted
    "A good stick is a good reason"
    1994 K75RT
    Moto Pages
    Nov 2009
    Vancouver
    I could see the scratched heads over such a smooth bike needing bar end weights
    Will have to see what my local vintage BMW dealer has to say, as the retrofit kits for the K75's and K100RS both state the kit is only good for bikes without bar end weights (image below). I would have thought the K100 would have a similar handlebar design with potential differences in bend and length
    Nov 2009
    Vancouver
    Talked to our local dealer, and while it does sound a bit tricky I'm going to give it a go. I still need something to quell these vibes through the bars and to fill in the unsightly holes I've gouged into the ends of the grips.
    Thanks Ted, much appreciated.
    Nov 2009
    Vancouver
    Ted, Did you simply push the anchors into the handlebars, and was it the same anchor for both ends? I thought the 'notch' had to go into a drilled hole on the handlebars.
    Nov 2009
    Vancouver
    Turns out, I'm an idiot with a non-standard heated "grip" setup.
    From what I have recently learned, the handlebars for heated grips have a ~90 degree open area to allow the wires for the heated grips to turn, and a notch on the bottom for anchoring the pin on the sleeve that you screw your bar-end weight into.
    What I have is the wire (wires?) wrapped around the handlebar directly, at least on the passenger side. No heated grips, but instead a heated handlebar
    A friend of mine that knows more about electrical wiring and machining will be stopping by on the weekend to see if this setup is salvageable.
    Sorry for any confusion, hopefully I can still post my noob-ish questions here
    Nov 2009
    Vancouver
    The beast, in pictures
    Nov 2009
    Vancouver
    I should have cut away the plastic cap at the end before taking this picture, it will be most likely heading to the scrap heap in the near future.
