Results 1 to 15 of 20
Thread: quick turn signal question
    new kid
    Nov 2010
    Athens, GA
    ...at least i hope this is a quick one, haha.
    the turn signal indicator light in the instrument cluster has stopped blinking. it blinks once and then stays off whenever i use the turn signal. the turn signals all work fine.
    someone told me once that this means one of the turn signal bulbs is out, or about to go out? i have no idea if thats true though.
    reading through the archives i found alot of people with the light staying on, or coming on erratically or intermittently, but this just blinks once and turns off when i turn the signals on, either direction.
    is it as simple as a bulb about to go out? or is it some kind of relay or connection problem?
    there is no such thing as "a bulb about to go out". either the filament is good and they work, or the filament is broken, and they don't.
    are your blinkers currently working as intended? if no, that's likely the problem. if yes, then its something else (but i've no idea what)
    new kid
    Nov 2010
    Athens, GA
    haha, yeah thats what i thought when he told me, it doesn't make any sense to have a light "about to go out." but i just wanted to give you all all the "information" i had, haha.
    anyway, yes the blinkers are all working as they should. just the indicator in the cluster blinks once and stays off.
    i suppose i'll dig around a bit and look at the relay and wiring and whatnots. i was just hoping the one blink was a sign of something specific. not a huge deal right now as the blinkers all work, but something to check on when i have some free tinkering time.
    Quote Originally Posted by apt13 View Post
    yup. jsut remember to cancel your signals once turn completed.
    Unregistered User dduelin's Avatar
    Jan 2008
    N. FL
    If the turn signals all work normally but just the green indicator light works once then goes out you might have a fault where the indicator bulb holder fits into the plastic film "circuit board"inside the intrument pod. The bulb holder has to make a connection at the place where the metal circuit strip has to make a 90 degree turn and the bulb holder contacts scrape away the metal it must make contact with. A bit of corrosion there creates enough resistance not to allow the bulb to work all the time like it used to. If you take the instrument pod apart you might be able to clean the contact area up and fix it or find the metal is just gone where it makes that 90 degree bend. Mine was like this and I rigged up a fix that involved tiny squares of aluminum foil to bridge the broken area. It worked for short periods of time but the real repair is to replace the circuit board which, the last time I checked, was still available. Me, I just got used to looking at the switch in my road/instrument scan so I don't ride too long with a blinker on. I had the pod apart several times for this and for an odometer repair and I wasn't sure how many times the fragile screw holes and plastic tabs that assemble the pod would stay together.
    Dave
    R100
    ST1300
    Russ 78goldie's Avatar
    May 2008
    Centennial, Colorado
    I too am experiencing the intermittent turn signal lamp from proper function and will check for these fixes, but the wildly flucuating volt meter needle alerts me to the turn signal being left on. Almost easier to see than the dim bulb in daylight....
    Living The Dream jewels's Avatar
    Nov 2009
    Albany, NY Area
    I recently had the exact same problem (1 blink on the dash indicator and nothing after that, left side , everything worked fine otherwise). I checked all turn signal lights and running lights (bike is an EML on a 1980 RT100 with Vetter fairing) and found one right bulb on the fairing where the glass part of the bulb was not totally attached to its sealed base, as well as loose in that base. Once I replaced this bulb everything worked great.
    Now I don't know if this applies to your problem, put some how this may help you trouble shoot it. Good Luck
    1991 R100/RT - 1984 R100/RS
    2006 KZ-14/ Hannigan HP
    1980 R100/EML-1964 R69S
    2013 F800GT
    Feb 2005
    Trinity, NC
    I was having a similar problem - indicator would flash 2 or 3 times then go dark even though the turn signals were flashing properly. It's the flasher/relay in the bucket.
    You can replace it with a new one. It's a pretty expensive relay. Or you can replace it with a standard electronic flasher relay from an auto parts store. I used a Tridon EL13, cost about $8. The stock flasher uses 4 wires, the EL13 uses 3. You can push the terminals out of the relay base and plug them into the EL13 or you can make up 3 short pigtails with .25 inch male and female terminals and just wire the 3 ends from the relay base to the new relay.
    Here's what you have:
    ___ - ground, not used
    31
    ___ ___ ___
    C 49 49A
    C --------> P indicator
    49 -------> X input
    49A -----> L load
    This standard relay will not give you the "bulb out" indication. You'll have to just just check your bulb visually every so often or at every pre-ride check.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    new kid
    Nov 2010
    Athens, GA
    thanks for the replies, guys. i'll check that relay this weekend. theres no way i'm spending the money to replace it with the official one, but the cheap relay work around sounds like a good idea. i remember reading about that elsewhere.
    May 2010
    look into the kissan flasher relay ... works great on my gs worth the dollars just for self canceling feature
    new kid
    Nov 2010
    Athens, GA
    went around to a couple auto parts places today and nowhere had the Tridon EL13 not could they order it for some reason. they only said they could order some kind of 30 dollar relay. i suppose i'll keep looking for the EL13 as i just can't get myself to spend more that 10 bucks on this problem, haha.
    the kissan sounds interesting, but do their products works on a '78 r80/7? i couldn't find anything on their site for the older bikes.
    Have you check for other replacements here?
    http://www.airheads.org/content/view/159/98/
    Jun 2007
    Portsmouth, NH
    Self cancelling turn signals for an airhead sound like a good idea. Any idea what unit to use for an 86 airhead?
    new kid
    Nov 2010
    Athens, GA
    Just to follow up, I found a Tridon EL13 flasher relay for 8 bucks. Easily installed it as per instructions on other posts and it cured my signal problem. The dash light even seems brighter than before, haha. Not sure if that's possible. Anyway, just wanted to say all is fixed, and for 8 bucks, rather than the ridiculous amount for a new authentic relay.
    Nardowell nardowell's Avatar
    Normal, IL
    My 1974 R90/6 is having the same problem. While at an Airhead meeting a long time airhead owner told me to check my bulbs in the turn signals and make sure they are all original equipment bulbs.
    I found that one of the 4 was a 1156 bulb which is not what is recommended. My guru said that this bulb has a bigger filament and that makes the flasher unit think that the bulb is burnt out and it won't flash correctly on the insturment panel.
    When I get the new (right) bulb from Hucky, I'll let you know if that was the right fix or whether my leg was being pulled.
    Nardowell
    Hoa Binh (Peace)
    Vietnam '69 and '70
    2012 R1200R classic
