Results 1 to 15 of 15
Thread: Boring Question...
    Dec 2008
    Morris, NY
    Boring Question...
    I've been doing some extensive work on my r90, and I finally got some numbers back on my bores. Both bores are nearly two one-thousandths out of spec. In addition, both pistons' ring grooves are one one-thousandths out of spec (the rings wobble and, as my awesome mechanic/machinist said, "skip along").
    I now seek your wise council on what to do next. He says I can likely hone the bores and install some new rings and keep on trucking for another year or two. Or, I can have them bored and get new pistons (more expensive to be sure).
    I can get the pistons from Motobins for ~$480. By the time I pay him for boring and whatnot, I'll be out ~$600. I've got my heads with Ted Porter now, so I'd wind up with an entirely new top end if I went that route.
    What would you guys do? Money isn't tight right now, but it isn't terribly loose, either. Things tend to snowball with this bike, and I wind up treating the project like dominoes. I'm all ready in there, so I might as well, so I might as well do that too...so I might as well... You guys know how it goes .
    ABC,AMA(LIFE),MOA,RA,IBMW MANICMECHANIC's Avatar
    May 2003
    Manitowoc, Wisconsin
    It's already apart, why do it twice?
    F.O.G.Rider, Rounder #6, Foundation Director
    Ambassador, Biergarten co-chair
    BMWRA Wisconsin Region Rep, security chair
    Registered User 88bmwjeff's Avatar
    Aug 2004
    Walnut Creek, CA
    Quote Originally Posted by manicmechanic View Post
    +1
    If you can afford it, you might as well get it done right this time, then you can start worrying about the next thing. I mean enjoy riding the bike.
    Jeff in W.C.
    1988 R100 RT (the other woman)
    "I got my motorcycle jacket but I'm walking all the time." Joe Strummer
    tripe my shorts James.A's Avatar
    Mar 2004
    central Illinois
    On a well maintained motor, it is nearly impossible to beat out the bottom end. Do this right, right now and you will not live long enough to have to do it again.
    James A. Strickland
    the "A" is for .........
    If I couldn't ride an AIRHEAD, I'd quit riding
    Dec 2008
    Morris, NY
    Anything else you'd guys do while you're in this deep? I'll have new bores, pistons, rings, seals, gaskets, heads, etc. Should I look at the lifters or connecting rods, or, or, or? All in the spirit of doing it right, of course.
    May 2003
    How is the clutch? I presume you've got a new rear main seal and oil pump O-ring. How about the timing set?
    Dec 2008
    Morris, NY
    New main oil seal, yes. Clutch has been fine. Timing's been fine. Splines were done the winter I bought her (two-ish years ago).
    Aug 2004
    Walnut Creek, CA
    Quote Originally Posted by brentde3 View Post
    Well, you didn't say how many miles are on the engine, but I'm guessing it's not a low mileage engine given the specs of the bores. That being said, I'm not much of an expert here. But, I would at least pull and check the tappets/cam followers. For peace of mind, you could pull the con rods and check the bearings and while they're off you can have them balanced with the pistons. Having things balanced will lead to a much smoother engine. Of course it's all time and money, and you need to determine how much time and money you want to put into it.
    Jeff in W.C.
    Albuquerque, NM
    Fitting new Nikasil pistons/cylinders will make for a much more reliable bike. Compare the cost at least.
    Kent Christensen
    21482
    Nov 2007
    Northwestern Ontario, Canada
    Thumbs up Nikasil jugs
    I was about to say the same thing when you beat me to it!
    Cave Creek AZ 85K100LT's Avatar
    Piston price out of line!!
    "I can get the pistons from Motobins for ~$480"
    I would shop around on those piston $240 for a single piston sounds high.
    Do some more research - got to be a better price out there!!!!
    Let us know what you find.
    1974 R75/6 W Sidecar
    1989 R100GS
    Dec 2008
    Morris, NY
    Hucky's first oversize R90 piston is $370 for one.
    Max wants the same. Any other ideas for sources?
    Piston cost
    WOW - I looked could not find any - Cost is crazy!!
    No ideas!!
    or call
    www.motoghost.com
    he might have a source.
    "I've been doing some extensive work on my r90, and I finally got some numbers back on my bores. Both bores are nearly two one-thousandths out of spec. In addition, both pistons' ring grooves are one one-thousandths out of spec (the rings wobble and, as my awesome mechanic/machinist said, "skip along")."
    If you put it together with these specs it will run fine for the next 100,000 miles - the beauty of Airheads!!!!
    or:
    http://cgi.ebay.com/ebaymotors/Pisto...Q5fAccessories
    1989 R100GS
    Grammarian no, Rider yes ISAMEMON's Avatar
    Jun 2006
    Kings Valley Oregon
    the e-bay pistons are sold already, was that you ?
    the nikasil is the way I would go.
    and if your gonna go bigger why not chase down r100 ?
    my previous bmw was not a nik bike and at 110k it was just out of specs, and I know I could have just slapped new rings in and been good for many a mile, as it was not burning oil as it was, but I instead found a cheap set of low miles jugs and pistons wihtin specs and went that route.
    my current bike is a nikasil bike, at 90k it needed a few things, including of course push rod tube seals,
    pulled it all apart and bores were within specs so just went with new rings so the nikasil deffinetly hold up, and this was nolt a nicely treated bike by p.o.
    while I was "in it" it was not a bunch more to put in new con rod bearings ( preventative and cheap) and got the pistons , rods balanced. I dont remeber the specs, but I was surprised how far out "balance" they were for being a bmw.
    I also pulled the lifters, and one was galling, you dont want to see pits, so I replaced two of the 4 and had them balanced as well, for the heck of it while everything else was beeing balanced, no added cost, why not, benefits ?????
    I also toook the approach, well its apart fix it now, and did tons more then originally intended, but Ill be good for another 100k plus ( for the lower end anyway)
    good luck with yours
    Wisconsin and Florida
    "He says I can likely hone the bores and install some new rings and keep on trucking for another year or two"
    I would go this route and keep my eyes open for another bike or engine with better parts.
    Probably if you weren't down and itching to ride you would have the patience or luck to
    find what you need long before you really need it. A lot of other crap can happen in two
    years to change your life forever. For what it is worth from my point of view why spend
    a small fortune and miss riding time with all that perfectionist crap. If it works just ride it
    till it doesn't work.
