Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: When should one consider a battery tender?
    Canada and the Alps
    Quote Originally Posted by EricJRW View Post
    Basically, at what point is a battery tender a good idea?
    If you use your motorcycle regularly, you do not need to use any charger. Only if the drain current is such that your breaks between rides drains the battery to say 12.6 V would you need a battery maintainer.
    I use one during winter storage.
    I use a CTEK 3300 which has an AGM/cold weather mode as well.
    Registered User EricJRW's Avatar
    Fort Worth, Texas
    Interesting point about checking the voltage...
    Going to have to play around with that. Still undecided on whether to tender or not.
    Do you think sitting for a week with no tender is bad? I'm hoping to make that my worst case scenario, though 2 might be tops (long vacation).
    '04 R1150RT (Biarritz Blue)
    Canada and the Alps
    Actually, having a battery sit on a battery maintainer isn't all that good for it. One is better off giving a battery a periodic charge.
    I use my battery maintainer to charge the battery on my R1150 GS Adventure and when its on float, I disconnect it.
    A day later my battery voltage is 12.9V, two weeks later it might drop to 12.8V and stays at that for till the third week.
    Jan 2009
    Orange County
    My 99 1100rt has the annoying abs fault on most starts. the voltage drops and the abs light start to alternated indicating "no abs" until you reset. Sometimes it only takes a restart and sometimes I have to ground out the plug under the seat.
    If I plug in the battery tender the night before , I generally do not get the as trouble light.
    Thats when I need the battery tender. Keeps the voltage at tip top level.
    Brad
    brhartw
    '87 K75S sold 94578 vin150106
    MOA138871
    '99 R1100rt Opal Blue
    Feb 2006
    If that is as long as the bike sits and you ride it enough to keep the battery charged when you ride it, I don't think you need a battery tender at all. I use my battery tenders until the green light comes on to indicate it is fully charged every 2 or 3 weeks in the winter. That us usually only an overnight charge.
    Black 86 R80RT Brown 03 R1200CLC
    Aug 2006
    El Lay
    I can only speak for my BMW and my Odyssey battery.
    The battery is marked to charge it at 14.4 to 14.7 volts, and float it at 13.5 volts.
    The alternator on the bike puts out 13.7 volts max. On a Fluke. Both the Clymer and the Haynes manuals say anything between 13 and 14 volts is fine.
    Soooooooo........ Riding the bike daily, which I do, does not charge the battery to Odyssey specs. My Midtronics conductance tester confirms this.
    For practical purposes, the bike starts fine, and the lights get brighter when I rev the engine, and the red light never comes on. But, I believe Odyssey's recommendation as to charging voltage is the way to get best service and longest life.
    The only way to get the recommended voltage into the battery is with an aux charger, unless someone knows how to increase the BMW charging voltage.
    Odyssey's OMAX-6A-1B charges at 14.7 volts, and floats at 13.6.
    The Battery Tender Plus, 021-028 has a charging voltage of 14.6 V and a float charge of 13.3 V.
    Canada and the Alps
    Quote Originally Posted by Kayseventyfive View Post
    That is far too low. There is something wrong with your regulator or your alternator (bad diode?) or you are not reading the voltage at the battery.
    And Clymer is full of you know what if they claim that.
    My voltage at the battery is 14.2V to 14.3V while cruising on my oilhead.
    I personally don't have much use for VRLA batteries simply because they do not outperform my flooded lead acid batteries, which by the way, I can maintain. VRLA batteries have their advantages such as lower internal resistance and therefore higher CCA, but what do I need the latter for when I am not operating at that temperature spec (0F/-18C I think it is). As for VRLA batteries having a much lower self discharge rate, thats all fine if the battery is stored off the bike, but the on-bike drains are so much higher, that the self discharge rate is of no importance.
    The CTEK has3300 a cold weather/specialty battery mode at 14.7V.
    Aug 2006
    El Lay
    Yes, they were read at the battery. Perhaps I will use this as an excuse to replace the alternator with the higher wattage unit, with the hope that the later one will charge at a higher voltage.
    Both Clymer and Haynes copy factory material, (and said the same thing) but I really don't know what BMW says. I can't believe BMW would be so imprecise as 13 to 14 volts.
    That is still a little low for what is marked on the Odyssey.
    Yeah, I think my next battery will be a regular flooded lead battery. Of course, some of this depends on the life of the present Odyssey.
    Thanks for the tip. I'll look into it. Do you know where it is made? Both the Battery Tender Plus and the Odyssey charger (which appears identical to a Schumacher SC600A) are Chinese, with the usual issues.
    I think Battery Tender actually makes money off their warranty, with the "Service Charges" they have. That is quite a business model, sell a product with the implied reliability of a ten year guarantee, then charge for the warranty service when it fails. My last BT never performed as advertised.
    Canada and the Alps
    If you have an oilhead, it already has a high output alternator. The one on my GS Adventure is 50A x 14V = 700W as listed in the specs. Other or older oilheads may be a little less.
    What are you running that you draw more than 700W?
    That is still a little low (14.2V to 14.3V) for what is marked on the Odyssey.
    Of course. That OEM alternator with the supplied voltage regulator was never chosen for an Odyssey battery.
    You do realize that there are many various voltage regulators available for your alternator, each with a different voltage setting.
    Hold on, not so fast.
    The reason why BMW installed a VRLA type battery are a few, one being due to the location of the battery. 1) They do not require topping up, simply because you can't. But if charged correctly on and off the bike, they should not gas and therefore water loss is very minimal. 2) They do not require an overflow/vent. If you install a FLA battery, then you will need to route a vent hose. Personally, I vent the end of the vent hose through the cap of a small 50 ml plastic jar with a small pin-hole in the cap for venting. You can place cotton padding with baking soda in the jar. This prevent droplets of acid hitting your frame/wheels, etc.
    BTW, a buyer for Costco that I met no longer buys Odyssey batteries. They had to many issues with them. Probably due to the charging systems on vehicles and battery chargers.
    Like everything else, most likely China.
    CTEK
    They have a nice assortment of add-on accessories.
    Aug 2006
    El Lay
    My 92 K75 has the low output 460W alternator. I have a later, higher output 700W version, but have not installed it yet. I wonder if it has a higher charging voltage.
    No, I didn't. Thanks for the tip. Both of my two closest dealers are also unaware, as I have asked them specifically.
    The online fiche for my bike shows only one regulator, a 12311459286, with no voltage stated. I would appreciate any further info on a higher charging voltage. Are these aftermarket, or what? The fiche for the later models with the high output alternator also show only one part number, with no mention made of the charging voltage.
    Waaah.
  11. #26
    Canada and the Alps
    Even the old one is quite a bit. I wonder what riders are running to need so much? I bet I'm hardly tapping into my available 700W, even if I have my Hella FF50s switched on.
    The voltage regulator is chosen for the purpose (how it is used and battery type, for example), be it a small or large wattage alternator. Voltage regulators also come with various temperature compensation curves.
    That appears to be the BMW part number. You are looking for the Bosch, Valeo or manufacturer's part number that is usually printed on the voltage regulator. From there, you can get the actual specs of the voltage regulator.
    They can be OEM or aftermarket.
    For example, here are a bunch of voltage regulators with various cut-off voltages. Its a matter of finding one that physically fits the alternator.
    I have a paper listing of Bosch voltage regulators that I got off the net, but I can't find the site at the moment.
  12. #27
    Aug 2006
    El Lay
    Looks good. Now, I gotta plan some down time to pull the old reg out, take some measurements and make a drawing, and then put it back together so I can ride it while I wait for the new reg to come.
    A quick look makes me think the old 460 watt gen might be easier to upgrade than the 700 watt one.
    Boy, that would be super if it becomes available. I would never need an external charger again if my alternator would alternate at the Odyssey recommended voltage. As it is, my bike gets a Fourteen-point-something charge from a car battery charger once a week, just to keep it happy.
  13. #28
    Canada and the Alps
    You'd be better off calling Bosch or Valeo with your alternator part number and asking them for a voltage regulator that meets your needs.
    BTW, some VRs have a trim pot under the cover, so that you can adjust the regulating voltage.
