Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: 18 year old coils
    Go Leafs Go CanadianSteve's Avatar
    Nov 2004
    Voluntown CT
    18 year old coils
    Seems like a silly question, but I"ll throw it out there. My 1992 R100RS has the original stock coils ... over 100,000 miles, 18 years. Time to change them ? Upgrades possible or stock BMW parts ? Thanks for any input.
    Steve
    steve now in CT
    moved from Toronto
    92 R100RS
    Polarbear Polarbear's Avatar
    Clovis,CA
    My '78 R100 has the original coils at 370000 miles, no issues. They are very simple and rarely break, bite my tongue, knock on wood! All the above miles are mine and the only bike in my life to live so long. I still ride her frequently. Randy
    Jul 2010
    http://www.motoelekt.com/
    That's the go to site for most of us here in the states for anything airhead and electric.
    Dyna coils are the standard aftermarket and reasonably priced at around $90usd
    Old man in the mountains osbornk's Avatar
    Feb 2006
    Marion VA-In the middle of some of the best riding in the country.
    Coils don't wear out. Like most electronics, they may quit today or last longer than the bike. My 86 bike's coils are still original and I think the coil is original on my 62 Fairlane.
    'You can say what you want about the South, but I almost never hear of anyone wanting to retire to the North.
    Black 86 R80RT Brown 03 R1200CLC
    New Hampshire, USA
    I'd buy a Dyna coil from Rick at motorrad Elektrik - compact, last a very long time, and will likely give you at least 18 more trouble free years for less $$ than the BMW part. You could get a BMW OEM part too, of course. Coils do get warm, and the BMW coils (from the early 80s at least) tend to develop tiny cracks in the coil housing as it ages - letting in moisture and causing intermittent problems and/or smoking short circuits. Your coil may last another 100K miles, or it could fail completely tomorrow, or it might start giving intermittent problems this summer. Anything that is electronic has a half-life, does wear out from heat and environmental effects, and needs to be replaced at some point. I design industrial electronics for a living - I'd say you've gotten very good service from that coil, but don't expect that it will last forever.
    BMWs in my garage: 1982 R65LS, 1978 R100/7
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by osbornk View Post
    HOWEVER, if they are the original grey crack-o-matic OE coils, they develop hairline cracks. The cracks let moisture in, and the coils stop making pretty blue sparks in the boom-boom rooms.
    The coils were the one of the first things I checked on my new-to-me '88RT, and sure enough, they were cracked -- I counted myself lucky that I did not have to undergo a water-intrusion test on the trip back from picking the bike up in Colorado -- perfect weather all the way back to VA.
    SO, take a *close* look at your coils. The characteristic cracks are true hairline cracks, so look hard. The cracks on mine were on the side of the body, longitudinally oriented from front to rear.
    Oh, and beware the slippery slope! Once I knew I had to replace the coils, the question was "should I get a coil I can use later with a dual plug set up? Well, since I'm contemplating that, it appears I need some valve guide work, so should I get the heads machined for dual plugs while they're off? And since I'm having the heads done, how much is a set of 9.5:1 pistons? And ..." Doesn't take long to get to the bunch o'$$$ stage!
    Mark Neblett
    Fairfax, VA
    #32806
    Never a dull moment RonKMiller's Avatar
    Tucson
    When I went through my '79 I took special note of all the electronic goodies - and even though everything looked good - I just decided to bite the bullet and replace the coils, plug wires and caps, along with cleaning all the connectors in the headlight bucket, etc. Tedious, but this way I figured I was starting out with a relatively "clean plate."
    I took somewhat of a gamble and replaced the coils with new made in Brazil Bosch coils that were a bit longer than OEM but still fit great, plus they are nice and shiny. These are standard fare that can be picked up at any VW repair shop.
    $35.00 each, (versus almost $100 for OEM?) although once again I may have screwed the pooch in the long run since I'm not 100% sure they have the exact correct output. I'm an electronics dummy, but I kinda figured 6V is 6V, and after all, it's an Airhead! We're not talking sophisticated electronics here...
    The points and plugs still look good, it fires up on first tickle, so I think everything is nominal. From what I can glean these coils should ONLY be used on 1970 to 1980 models so beware! I believe it has to do with resistance.
    KonTourSeat.com "It's Like Butt-ahh!"
    Fenwick, Ontario Canada
    1977 R100RS 487,500 miles same stock coils.
    If it ain't broke... don't fix it!
    Knights of the Roundel #333
    1977 R100RS with 516,000 miles
    Registered User 88bmwjeff's Avatar
    Aug 2004
    Walnut Creek, CA
    It seems that most say they don't wear out, but mine did. Although I have the grey Crack O matic coil, mine was not cracked. However, it was putting out a weak spark. When I replaced the coil, my RPM's increased. I don't remember the amount, but it worked out to about a 20% increase.
    If you're not having any issues, don't worry about it.
    Jeff in W.C.
    1988 R100 RT (the other woman)
    "I got my motorcycle jacket but I'm walking all the time." Joe Strummer
    Registered User kwb210's Avatar
    Jul 2009
    Washington, the state
    Motoelekt has this coil for the 1970 to 1980 airhead and notes no mounts. Has anyone that purchased one have a comment on the mounting? I am going over my bike this winter and coils are on the list to check.
    Thanks!
    kurt
    ""Green 3.0 $95 each with mounting bracket, $150 pair (no mounts)
    GREEN coils have 3 ohms primary resistance, for points ignition systems and older dual-plug applications.
    Use ONE coil for ALL MODELS made from 1970-1980 that came from the factory with POINTS ignition. Comes with single mounting bracket. Also good for use on /2 conversions with a 12 volt system.""
    Quote Originally Posted by 60755 View Post
    1977 R100/7 1972 R75/5
    1974 R90/6
    www.airheadrentals.com
    "Objects in the mirror appear to be losing" unk
    Administrator 20774's Avatar
    Quote Originally Posted by Darryl View Post
    Darryl -
    ~14.3K miles per year...that's pretty impressive!!
    Nov 2009
    Central Ontario, Canada
    Quote Originally Posted by CanadianSteve View Post
    Steve
    My R100GS always starts up on one cylinder and then the other after a few turnovers.... original coils. I have purchased the motorrad Elektrik coils and will post if they and new wires bring life to the beast in balance faster.... I hope so... if that is not the issue fuel will be. I also purchased the diode upgrade and voltage regulator to ensure reliable charging. Did not go for the increased output alternator, the one I have seems to keep up with my electrical demands.
    R's Graham
    1991 R100 GS "Bumble Bee"
    2007 KTM 525EXC-R True Adventure, 2010 Husaberg FE450
    Past BMWs: '68 R50/2, '77 R80/7, '87 R80GSPD, '76 R60/6, '85 K100RS
    Simpleman
    Dec 2009
    Florida
    My 78 R100/7 have the original coils and they are fine.
    Professional Slacker
    Mar 2010
    Deland, Florida
    6V volkswagen coils from Autozone @ $18 each. They seem to work extremy good. Same specification as original. Duh.
    Tucson
    Quote Originally Posted by Dap_Spackled View Post
    I would be surprised if yours ARE made by Bosch.
    Autozone touts that it's coils are made by Wells - a "global supplier" - and we all know what THAT means: Probably made in China, hopefully made in Mexico or Taiwan. It's still garbage compared to genuine Bosch components.
    For me, spending an extra $17.00 on a name brand coil recommend by an acknowledged expert in Airhead ignition (not me, certainly) is a no brainer if I have to risk being stranded somewhere - or worry about frying something REALLY expensive.
    This brings up the fairly recent discussion of supposedly genuine BMW points - until it was discovered that the rubbing blocks would not even allow them to be adjusted at all since they were not even close to BMW specs. They were out and out fakes.
    Coils do have very specific OHM measurements and vary dramatically among supposedly similar coils - from what I can tell this is VERY important.
    All kinds of counterfeit cheap stuff out there. You pays your money and you takes your chances.
