Results 1 to 9 of 9
Thread: 08 R1200RT - advice please - Co-Pilot, Zumo 660, SPOT & installation
    Registered User cowboyatheart's Avatar
    Feb 2009
    Garden Bay, BC, Canada
    Hi all,
    Happy New Year to each and everyone of you! May this year bring you much success and joy.
    I am planning my farkle purchase for my 2008 R1200RT, and I am asking for all advice on installation etc.
    Any photos you have of your installation would be very helpful too.
    I will start with my list, then ask my questions. Thanks in advance for your help and advice.
    Neil
    604 258 8548
    1. http://www.bmrproducts.com/products.php?cat=31
    co-pilot shelf
    Gusset Accessory arm (for Spot?)
    Adjustable Tilt Mount Bracket (I assume I need this to mount the touratech mount to)
    Zumo 660 sun visor
    2. http://www.touratech-usa.com/Store/1...-Locking-Black
    TOURATECH Zumo 660 / 665 handlebar mount V2.0, Locking, Black
    3. http://findmespot.ca/en/index.php?cid=102
    the new - Spot Satellite GPS Messenger
    4. http://www.gpscentral.ca/products/garmin/zumo-660.html
    Garmin Zumo 660LM
    Questions
    And please note that I have, virtually, ZERO installation experience & knowledge with everything regarding a motorcycle.
    1. Are there any rubber mounts or vibration installation devices required? If so, what and where to do I get them?
    2. I understand there may be a free connector for power for the Garmin Zumo available under the dash near the headlights?
    2 (a) Is this so?
    2 (b) If so, what part do I need to get from BMW?
    2 (c) AND will it then connect directly or do I need to order additional electrical wiring (etc)?
    2 (d) If I need additional electrical stuff, can you please be specific?
    3. Current thinking is that it would be good to mount the SPOT device on the Gusset Accessory Arm. What are your thoughts? How would I mount (any suggestions)?
    4. Do you know if the Sun Visor will work with the Touratech mount?
    5. Do I need the bmr tilt mount to attach the Touratech mount onto it?
    6. Have I missed anything?
    Thanks in advance for your help, recommendations and directions.
    Cowboy at Heart, info@Ltdnow.co
    Moringa: Healer | Nourisher | Beautician | Humanitarian
    www.Meet-Moringa.com For optimum health and energy.
    Hammam Hammam's Avatar
    May 2010
    Quote Originally Posted by cowboyatheart View Post
    Hi all,
    Neil
    604 258 8548
    co-pilot shelf
    Zumo 660 sun visor
    Garmin Zumo 660LM
    Questions
    2 (a) Is this so?
    That is a lot questions all at once. Maybe a bit overwhelming. I have the Zumo 660 installed on my RT (previously on my GS) and I'll try to answer a couple:
    1) The Touratech locking mount has rubber mounts built-in which do a decent job at dampening vibrations.
    2a) Yes. If not under the dash, then somewhere near.
    2b) I think I remember I had to get some kind of BMW adaptor. Yout dealer will tell you which.
    2c) I think it will connect directly to the Canbus system, and will thus be protected.
    4) The photographs showing the Sun Visor seem to show that it works. The opposite would be surprising. I have another kind, whis is attached with hook-and-loop on the sides and top of the GPS, and a cut at the top of it to accomodate the Touratech mount.
    Tha's about all the help I can give. Some posters may disagree with me. The Spot thing, i know nothing about.
    Oh, one thing: I had my Zumo installed on a special BMW bar on top of the dash, just under the screen. That way I keep the road ahead in sight even when I glance at it. I don't think I would have liked it on the handlebar. YMMV.
    Feb 2009
    Zumo mount
    Quote Originally Posted by Hammam View Post
    Zumo mounting
    Thank you so much for your feedback. Yes lot's of questions, I thought it would be good/beneficial to lay it all out. Perhaps not!
    Can you tell me more about your special BMW bar and how your Zumo is mounted? A link to the product perhaps?
    I choose the co-pilot for the above dash mount. Didn't know there was another product that could do the same thing.
    Thanks again.
    Registered User C172MyP51's Avatar
    Sep 2011
    Hershey, PA
    RAM mounts
    I mount my SPOT over the brake fluid reservoir using a RAM mount. I got mine at dualsporttouring.com but other places sell the BMW part. It mounts on top of the existing metal cover, but you have to use the (included) longer metal screws.
    Generally, I don't think we're supposed to "advertise" in our signatures. Probably against the BMW MOA forum rules.
    -Scott
    Hershey, PA
    IBA# 41,645
    AMA# 278***9
    2006 BMW R1200RT "Pacific Coast II"
    May 2010
    The bar is a BMW accessory that was installed by my dealer. I also bought a couple of clips to fix the Touratech cradle (not exactluy the same model as yours) to the bar. I don't have specific photos of the installation, but I join a crop of a bigger photo to at least show you the general idea. You can also see the sun shade I have, which is called The Hood. Hope it'll help.
    May 2010
    Here is another one (I don't know why I can't upload two photos in the the same post.)
    RAINEY 187132's Avatar
    Sep 2012
    Grand Rapids, MI
    I live fairly close to the dealer and just decided to let them install it for me. I used the BMW bar as showed on a previous reply on this thread. I know some people like to tinker with things themselves, other just like to save money by doing it themselves and then there's me thought process. The dealer does it everyday, has all of the parts needed to do it properly and will stand behind the install.
    I know this isn't a direct answer to your question, but I would consider a dealer install.
    Best regards,
    Jason
    Jason
    Grand rapids, MI
    2012 BMW R1200RT
    Jun 2009
    Here is the BMR Co-pilot mount with BMR adjustable mount and touratech mount on my '09. I have a Valentine One on one accessory shelf and the Zumo 665 XM antenna on the other.
    I highly recommend the BMR Co-pilot. Solid as a rock and excellent quality. Puts Zumo in very convenient spot with excellent line of sight. I have had no need for a sun visor.
    Plenty of room for a SPOT on a shelf.
    I have recently added a 5 LED mini light bar to the top of the Zumo that is dsigned for and plugged into the Valentine One and warns me of radar directly in my line of sight. (Not in pic)
    Also photo was taken with Cee Bailey's Dark Grey Tinted Sport Shield.
    2011 R1200RT ka5ysy's Avatar
    Oct 2006
    Prairieville, Louisiana
    2011 - R1200RT - Wunderlich mount
    Nice position, no vibration.
    MSF #127350 NAUI #36288
