Results 1 to 9 of 9
Thread: Big Agnes Pad for Big Rider?
    Apr 2010
    Western MA
    I'm looking for feedback regarding a Big Agnes (or similar) pad that will be comfortable in a tent for a 5'9", 230 lb side-sleeper during nights that are above 30??. None of my camping is done on rocky/rough terrain.
    Based on the charts, it looks like the Big Agnes candidates might be the:
    - Dual Core
    - Insulated Air Core
    - Memory Foam
    With most pads, I awake with sore hips and shoulders (the widest parts of my body!). Forty-five years/pounds ago, all I needed was a fairly thin Thermarest pad when backpacking. Well, that was then and this is now.
    I've tried several cots which do offer relief, but I don't want to cart, setup, and provide the protective floor accommodations needed for a cot.
    Anyone of a similar weight/side-sleeping position have a good recommendation for a big rider?
    TIA,
    Theo
    Dum vivimus vivamus TED's Avatar
    I upgraded my 15 year old Thermarest to an REI 1.75" pad earlier this summer. It is nice and does a great job - 5'9" 220lb side sleeper myself. I originally wanted to get the Big Agnes Air Core (2.5") but I didn't want to have to carry a pump or have to blow it up. Than I saw the Big Agnes Pumphouse and that changed everything.
    The pumphouse:
    It is a drybag, a big air bellows, and a pillow all in one. The top opening has a rigid edge that can be rolled then clipped down like many high-quality, lightweight drybags. It also has a cone/nipple attachment at the bottom that one can secure over an air mattress blow-up valve and by opening the bag, closing the top and squeezing one can completely fill the Air Core full-size pad in under a minute. Lastly, it makes a great pillow.
    I got the Pumphouse and the Air Core mattress and enjoyed my first really comfortable sleep in a tent in many years.
    Then I got a Big Agnes sleeping bag, the kind with no insulation on the bottom, just a sleeve for inserting the sleeping pad. Another huge win, worked better than advertised. Warm as my regular sleeping bag and pad combo, w-i-d-e so sleeping on my side is a breeze as I can comfortably turn inside the bag, and best of all, no sliding off.
    Lastly, the BA pad/bag/Pumphouse combo pad packs down tiny, so much so that not only do both pad and bag fit inside the Pumphouse (now a acting as a stuffsack), all three can fit easily inside my helmet (or inside my 22-liter topcase with lots of room to spare.)
    You'll like the Air Core, I would advise adding the Pumphouse - and checking out the sleeping bags as well.
    Ted
    1994 K75RT
    Moto Pages
    Braintree, MA
    Quote Originally Posted by THEO View Post
    I've got 70 pounds on you, little fella. I have a Fat Agnes pad and it works well. I also have a Thermarest NeoAir that packs to about the size of a 32 oz can of tomatoes. Both are comfortable for me, mostly a stomach sleeper, but I spend about half the night on my side.
    Salty Fog Rally 2007, 2009, 2011, 2012
    -Tom (KA1TOX)
    Jul 2005
    Colorado
    I've got 20 lbs on you, same height. I have the BA insulated air core and it works great.
    Polarbear Polarbear's Avatar
    Clovis,CA
    15 degrees:)
    Yep, I camped in February in Texas and the BA setup kept me warm to 15 outside my tent. Inside wasn't much warmer. Not even a coolness, as I stayed warm. 6' and 250 then and since down to 200. Randy
    Registered User 119240's Avatar
    Cambridge,Ma
    Has anyone tried an Exped mattresses ? http://www.exped.com/exped/web/exped_homepage_na.nsf
    '91 K75S, '06 K1200S
    BMWMOA #119240
    YB # 1463
    NRA #154764753
    Jun 2008
    SF Bay Area
    Quote Originally Posted by 119240 View Post
    Heaven. I've an Exped downmat 9 DLX. downmat means it's filled with down. 9 says it is 9 cm thick when fully inflated. DLX is for the longer/wider version. Because moisture is not good for down the mattress has a built in pump that works OK. My first mattress used the stuff sack as the pump. It sprung a slow leak at the valve and exped replaced the mattress. The valve is completely different on the current version. Simpler and much less likely to fail.
    http://www.youtube.com/watch?feature...&v=lpa9qNictSs
    The video shows a little trick at the end to make sure the pump area is inflated as well as the rest of the mattress.
    Eastern KY
    Age 67,weight 215(neked), bad back,etc..
    If I'm carrying the pad=Thermarest tiny backpacker version. If bikes carrying the pad=Wally World/Coleman Queen Inflatable Mattress That takes up the whole floor of my Kelty 2x tent & easily fits in the bottom of my topcase. Blow it up with your bike tire pump. Moisture and cold don't get to you (or your stuff)as easy,soft & cushy @ night and price is low.
    Apr 2010
    Western MA
    Thanks for the responses. The Exped is an interesting option to the BA. Good to know there are other folks my size who find these comfortable.
    Spring, here I come!
    Theo
