Results 1 to 15 of 17
Thread: 2 GS911 Questions
    Oct 2010
    Albuquerque
    2 GS911 Questions
    Can the GS911:
    Change idle speed?
    Calibrate the temperature sensor?
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    No. It can read and clear fault codes, capture the readings of various sensors in real time, and perform some service operations such as parking the stepper motors and resetting the service needed indicator. The service functions supported vary according to the type of bike you have.
    http://www.hexcode.co.za/products/gs-911/bmsk
    Feb 2007
    Maryland
    There's a virtually brand new one for sale in the flea market.
    Chuck
    10 R1200GS
    94 VFR 750
    88 R100RT (dearly departed)
    Feb 2007
    Maryland
    As i recall it actually does something having to do with the idle speed. Perhaps setting it temporarily as a baseline for synching the throttle bodies. Have a look at the online info on their website to be sure.
    Chuck
    10 R1200GS
    94 VFR 750
    Jun 2008
    SF Bay Area
    Quote Originally Posted by 3moskvichi View Post
    It can lock the steppers on hexheads so you can measure the idle balance, not the idle speed. I'm not aware of any way to adjust the idle speed on a hexhead. Perhaps the dealer can do something with the GT-1.
    Merry Christmas
    Getting lost...
    Aug 2005
    NE Ohio
    It does have the ability to reset the idle steppers for idle calibration but it cannot change the idle speed. The steppers can drift because they cannot determine exact position.
    This is the same procedure that a dealer can perform on the GT-1 when a customer complains of poor idle.
    I have used it with little success but others claim it has improved idle.
    2007 R1200RT
    1999 R1100RA
    Quote Originally Posted by Motorwerk View Post
    Actually - as best I can tell - the idle steppers are reset on every startup IF you let the bike complete it's startup sequence (where the instruments do their fun thing..)
    Next time you go to start the bike, put a finger on the left side stepper motor before you turn the key on. Then turn the key to on - you'll feel the stepper do a full close and then open slightly. Unless I'm quite mistaken - it's exactly the same thing the GS-911 tells it to do for a reset. I suspect you are someone who often allows the bike to complete the startup sequence before hitting the starter button. Since I noticed this - I've tried to also.
    FWIW - I spent a lot of time chasing an intermittent bad idle on my '07 R12R. I finally found it - a damaged wire shorting to ground on the O2 sensor harness was intermittently killing the O2 signal from one sensor (#2, which is on the left cylinder.) Found it with the GS-911's sensor tracking function. Without the GS-911 I'd still be scratching my head over it. Great tool!
    Registered User talmadge_w's Avatar
    May 2008
    Houston, TX
    Not sure what you idle issue is but you can also force the bike to relearn idle by turning the key on (not start), open the throttle fully and allow to snap closed, repeat two more times, start the bike with no throttle.
    This solved the poor idle I acquired after several very cold starts requiring lots of throttle...
    Talmadge
    Talmadge Wright
    '12 R1200 GSA
    Getting lost...
    Aug 2005
    NE Ohio
    Understood guys, thanks.
    Don, I have noticed the same upon startup but from what I have read and come to understand is that the steppers are told to move so many increments one way or the other but they have no idea where they are in relation to position. Apparently, the reset puts them back on track. And this is exactly what the dealer can do - apparently it's documented in a service bulletin.
    Take a look at this from Hexcode - http://www.hexcode.co.za/techinfo/iac
    My idle issue is very intermittent and normally is at its worst when the bike is fully warmed maybe after an hour or so ride and can get slighty worse the hotter it gets. Come Spring I plan on tracing the O2 sensor wiring to check its connections based on your findings. Hopefully, it's routing is similar to your R and can easily be exposed - here's hoping.
    2007 R1200RT
    1999 R1100RA
    Hmm.. link doesn't work.
    Actually Stephen and I have discussed this at some length, and while it's still speculation, I think we both agreed that it's entirely possible (and probable IMHO) that BMW included the recal process as part of the startup sequence - if people let the sequence complete. Since the function is there in software (and triggerable by the GS-911 or dealer's computer,) it would be trivial (and make sense) to have it triggered by the same trigger that does the instrument reset.
    Since your bike is an '07 - it's certainly possible. On the R12R forum that I hang out on, several people did look at theirs after I found the problem with mine, and none of them were routed quite the same way.. (some were kind enough to include photos) but it's possible whoever the hamfisted wire harness installer was the day mine was built also had his hands on your '07.. It is lots easier to check on an R12R since the wiring is hanging out in the open if you lay down next to the bike.. it's pretty well concealed on an RT.
    Good luck!
    Quote Originally Posted by Talmadge_W View Post
    Talmadge
    On the hexhead - it only requires turning the throttle fully open with the key on for the ECU to learn the throttle position. The oilhead did require the three-time sequence, after resetting the ECU by disconnecting the battery.
    Getting lost...
    Aug 2005
    NE Ohio
    Yeah, it looks like the entire site is unavailable at the moment.
    Don, have you tried using the reset on the GS-911? Seems it takes a moment to go through as you can hear the steppers being moved around. Not sure it's quite that extensive on the startup routine - or if it even needs to be.
    2007 R1200RT
    1999 R1100RA
    Rocky Bow BMW Riders #197 bogthebasher's Avatar
    Calgary AB
    Hexcode.co.za Down?
    [QUOTE=Motorwerk;641543]Yeah, it looks like the entire site is unavailable at the moment.
    [QUOTE]
    Is this common? I got a new GS-911 for Christmas and have been trying to access the site since receiving my device with no luck for days. I was beginning to think they were out of business. Without access one cannot even begin doing setup or downloading software.:
    Ken
    [2008 R1200RT (Biarritz Blue) - Mine]
    [2007 R1200RT (Sand Biege) - Hers]
    Jun 2008
    SF Bay Area
    [QUOTE=bogthebasher;641630][QUOTE=Motorwerk;641543]Yeah, it looks like the entire site is unavailable at the moment.
    They are on vacation. This was posted to the GS-911 mailing list:
    Wishing you all a happy and Merry Christmas!
    We are closed for our annual summer break. Our office will reopen on 10 January - until that time email support will be intermittent, at best.
    Best wishes
    The HEX Team
    I suspect no one is home to check on any web problems.
    Yes - it sounds the same, but IIRC, the GS-911 reset does it twice.
