Page 1 of 4 123 ... LastLast
Results 1 to 15 of 51
Thread: Windshield supports 2009 R1200RT
    2011 R1200RT
    Dec 2007
    Hoosier
    Okay, got a Cee Bailey windshield at one inch taller and three inches wider than stock. Do I automatically need aluminum supports or can I wait to see if the stock supports break first?
    2012 Midnight Blue R1200RT
    Sheboygan, WI
    Cool
    Quote Originally Posted by Motodan View Post
    You could wait, but I'd put money on those OEM struts snapping within 24 months.
    If I were you, I'd just order up a pair of bullet-proof supports, swap them for the OEM pot-metal units, and never worrry about it again (especially in adverse weather!).
    PM me for the source.
    But again, that's just me..............
    Kevin Greenwald - Touring Tips Editor
    Nationally Certified Law Enforcement Motor Officer (Ret.)
    MSF RiderCoach # 121656 (BRC,SBRC,IS,IME,SMARTrainer,THE REF Staff)
    Iron Butt Association Member # 34281
    Sep 2007
    So. Calif.
    I bought the Cal Sci windshield and also "automatically" installed a pair of the deluxe supports. Now I find that I'm not so enthused about the non-stock windshield and have re-installed the OEM one. That makes the deluxe supports somewhat superfluous.
    My point is, it looks like I could have saved some $$ and labor if I hadn't been quite so hasty in buying the supports. I should have given the aftermarket windshield a longer test period to see whether I preferred it over the OEM one. (And hopefully the stock supports would have lasted for my full test period).
    '13 K1600GT
    '08 R1200RT (gone), '04 R1150RT (gone)
    '05 R1200GS (gone), '73 R75/5 (long gone)
    Spring Lake NJ, USA
    Motodan - I'm adding the bike model/year to the thread title. That will probably come in useful for other owners of an RT who are considering a different windshield. Please consider doing this yourself when starting threads..
    And have a great Holiday!
    Don Eilenberger, Forum Moderator, MOA Ambassador - http://www.eilenberger.net
    Spring Lk Heights NJ NJ Shore BMW Riders New Sweden BMW Riders
    '07 R1200R (current ride) and some bimmers.. and a Porsche
    Registered User rodstanhope's Avatar
    Nov 2009
    Ringgold, GA
    Mine lasted almost 2 days after installing the cee bailey's +2. I would order them asap!
    I do ride in TX and I'm convinced windy conditions are to blame.
    Rod
    95 K75
    07 R1200RT
    Survivor AKBEEMER's Avatar
    Jul 2007
    Land of the Big Sky
    Can you not divulge the source more widely? Please.
    Kevin Huddy
    24790
    Team Pterodactyl Montana Outpost
    Canyon Creek, MT USA
    God? What god? RoboRider's Avatar
    May 2007
    Raleigh, NC
    http://www.westtoolff.com/index_file...l_products.htm
    The above is the web site link.
    I have a set for my Cee Bailey. The old ones broke after about a year. The new ones are great.
    Also, if you get a windscreen that is too tall, you can cut it to your own size. I made a post on how to do this but it got deleted (it was linked to XPLOR and XPLOR aint no more!).
    Rob C. , Raleigh, NC
    '05 R12RT, R90/6
    2007 CBR600RR & 09 V-Star
    Suzuki DR 350
    Sheboygan, WI
    Smile
    Quote Originally Posted by AKBeemer View Post
    Gladly, though I've posted this before (but will always do again if there is an interest):
    They are milled out of a piece of 2024 Aluminum and will be powder coated black. You have to remove your original plastic bushings and transfer them to the new ones. The cost of the BMW ones are listed at $70.00 each. The cost of these are $45.00 each plus shipping.
    Contact info is:
    Don Westra
    West Tool & Design Inc.
    1220 North Tower Road
    Fergus Falls, MN 56537
    Phone: 218-739-4990
    Fax: 218-739-4989
    email: Don@westtoolff.com
    Website: http://www.westtoolff.com/index_file...l_products.htm
    I would try calling in your order over the phone. That worked easiest for me.
    Good Luck!
    Sep 2008
    Wilmington, NC
    If you happen to be on the road more than a short distance from home base when you break the stockers with an oversized screen, you won't be a happy camper. Stiff crosswinds and vibrations increase the chance and speed of breakage.
    The West brackets aren't going to break and you can either give the stockers away or pitch them after changing.
    Change only takes a few minutes and doesn't need any fancy tools.
    Got curvy roads?
    Feb 2010
    Lee's Summit, Missouri
    replace?
    Hmmn... I have seen this topic many times before. I bought an extra large ztechnic windshield. I asked ztechnic point blank if I needed to replace the stock pieces. They advised no, as the oem pieces are made of high quality polycarbonate (if I remember correctly) and said there is no need for replacement. Granted I have only put 10k miles on the bike after getting the new shield. There are no signs of problems. I have traveled through some nasty winds (cross winds, straight winds, sudden blasts) in, Kansas, Wyoming, Utah Oregon. Granted I do not run with the shield all the way up. The strut pieces are either parallel or slightly elevated during my normal riding. I did run it all the way up through one rain storm. As of now I have no plans of purchasing replacements. If someone else has experience with this shield, please advise.
    BMW MOA, AMA, KCBMWMC
    09 R12rt, 01 KTM 200 Exc, 84 Honda Big Red
    98 Katana 750 (gone to a new home)
    Aug 2004
    SW Ohio
    Quote Originally Posted by Bezdelnik View Post
    I changed mine when I changes the stock screen to a large cee bailey. The stock supports were pot metal, not polycarbonite. (2007 RT)
    I am guessing BMW made them that way to break if you were being thrown off the bike.
    2007 R1200RT
    2000 R1100rt sold @ 72,000
    Iron Butt #24605
    Sheboygan, WI
    Smile
    Quote Originally Posted by alanrd View Post
    To my knowledge, they're still pot metal (slag).
    By the way, even if BMW did transition to "polycarbonate,' this is merely a thermoplastic polymer, going by the trade name of Lexan - in other words - a simple plastic.
    If you boost the stress (pressure) on the shield, it's probably only a matter of time before a pot metal strut snaps, oddly almost always in the act of lowering. Happened to me and others that way after about 18 months, but that's the kicker - not an exact science when that stress fracture will finally jump up and bite you.
    Sep 2008
    Wilmington, NC
    Stock brackets are not plastic- the writer is either confused or he got bad advice. (Perhaps he is simply mixing up screen materials- polycarbonate or acrylic)
    Re the Z Technik screen I'd hazard an opinion that it is a bit less likely to lead to early bracket breakage than some of the Cee Bailey's, Aeroflow and others that are very large. Here's why I think that might be true BUT its only a guess.
    Any added larger screen "hits" more air than the stocker. And the extra frontal area is obvious especially in gusting crosswinds coming from forward where with some screens it can feel almost lke the bike is bogging in molasses when it encounters a sizeable gust In trying several screens on my 08 RT I noticed this feeling varied a lot with different screen types. The Z Technic screen is a little more flexible than some and perhaps because it is a little narrower at the base has less of the resistance feel (though a good bit more than stock) than others such as the (wider at the base) Cal Sci, etc.
    Still, precisely because having brackets break riding is no fun (and potentially dangerous) and I do a lot that is a distance both from home and dealers, it seemed prudent to either replace or carry spares and there seems no reason to carry extra stock parts that are both worse materials and more expensive.
    Speed also no doubt influences breakage. Most of my riding is above 70 mph, some a good deal higher. If I rode around town a lot or near a dealer, I might not care but I wouldn't own an RT just to do that- there are better "town" and "urban" bikes for sure- The RT is in its element when combining speed with distance being more or less the 2 wheeled equivalent of gentleman's sport coupe, rather than a sports car or 4 door sedan.
    Above comments are for 05-09 and may not be relevant to 2010 and later- don't know if they improved the bracket when they changed the screen design for 2010.
    Seem to remember hearing they were strengthened but have never checked.
    Anyone know?
    You don't need to be any sort of engineering genius to understand that using fatigue prone pot metal for a stressed bracket is simply a dumb idea that is all about saving $, not about quality parts. There are other examples of poor design choices on the RT such as centerstand bolts that are both a size too small and can impose high shear loads on the bolt threads (and fortuneately break only rarely given the hazards of such breakage), the fpc well that collects water, etc....
    Registered User barry5k's Avatar
    Jun 2009
    Elk Grove, CA
    I also have a Cal Sci windshield but never even thought of changing the brackets. You guys have scared me straight! I see that they are $90 on that Westtool site above. Are they really necessary and are there other sources that may be cheaper? I wonder if anyone has actually had broken brackets while riding?
    Into the Wind
    2007 R1200RT
    2007 Kawasaki Vulcan 1500 Classic
    Sheboygan, WI
    Smile
    Quote Originally Posted by barry5k View Post
    First off, this is a subjective decision on your part - get them - don't get them - your call.
    Since the Cal-Sci shields have a hole in them (and thus some back-pressure in play), maybe you don't need the beefed up supports.
    As for other sources - don't know - liked the Westtool ones just fine.
    As for breaking while riding, mine snapped after 18 months of stressing the OEM struts with a larger, Cee Baily shield.
    Good Luck with whatever you decide, and Ride Safe.
