Results 1 to 2 of 2
Thread: R1200 "Camhead" 2010+ Maintenance DVD
    Mar 2004
    Alexandria, VA
    Now Available!
    Find more info here: http://www.jimvonbaden.com/R1200_Camhead_2010+.html
    Also, look for combination sales here: http://www.jimvonbaden.com/Combinati...ales_DVDs.html l
    This video covers all of the following categories, and is designed to allow you to complete all the requirements for maintaining your bike to BMW specifications. It is designed for ALL R1200 series Camhead 2010 and newer motorcycles though it is centered around the R1200GS/A since that is what I had available for filming.
    Note: The DVD was designed around the R1200 series BMW from 2010 and 2011. I will be adding a tutorial on removing the body panels on the R1200RT/R to the same section in the future.
    1. Oil change, engine, with filter
    2. Gearbox-oil change
    3. Oil change, rear wheel drive
    4. Checking valve clearance
    *Replace all spark plugs
    5. Changing brake fluid, front/rear brakes
    *Visually inspecting brake pipes, brake hoses and connections
    *Checking front brake pads and brake discs for wear
    *Checking rear brake pads and brake disc for wear
    *Visual inspection of hydraulic clutch system
    6. Replace air filter cartridge
    7. Replace belt for generator
    8. Checking spoke tension, adjusting if necessary
    9. Correcting engine synchronization (for maintenance)
    10. Reading fault memory
    *Setting service-due date and service countdown distance
    I have included the necessary tools, supplies and torque specifications to complete all the listed services. I have also added many helpful tips and notes to make this as simple as possible.
    See DVD Description Page for available tool lists and downloads of the service schedules.
    Consider this, the tool to remove and install the alternator belt is nearly $150, I teach you how to do it with no special tools, a savings of $125 right there!
    A typical 6K service will run you around $300-350, depending on location. The brake bleed alone can run as high as $200.
    What I did not include, since I felt they were self explanatory, was how to check your oil, tires, lights, and side/center stand.
    The DVD should assist those of you on the fence in deciding you CAN do these expensive services yourself, and save money for those all important farkles, and gas for riding!
    The DVDs are available for $25 plus $3 shipping to the continental US, $5 to non-US shipping.
    I will accept Paypal as this is my preferred method of payment. I will also accept money orders, and personal checks for US orders ONLY, and with a US bank only. See check sales for instructions.
    Feel free to e-mail or PM me if you have any questions!
    Jim
    PS Don't forget the other videos I sell, and the free tutorials on the R-series BMW maintenance and repair in my Pictorials section! http://www.jimvonbaden.com/Pictorials.html
    Mar 2004
    Alexandria, VA
    First set shipped out. If you ordered one, please let me know what you think.
    Thanks,
    Jim
