Results 1 to 4 of 4
Thread: 48L top case latch problems
    Jun 2009
    Clearwater, FL
    Has anyone had success repairing a latch problem on the top case? On mine, the latches on the left do not move, remain in the unlatched position. Ones on the right work OK. Is it difficult to remove the inner liner to get at the mechanism? I am fairly handy but have this fear of removing screws and bolts, then parts fall inside and get lost, Is there some place where you can get a diagram of how these cases are put together? Any help would be appreciated.
    Jul 2005
    Colorado
    Depending when your case was made, BMW has a service bulletin out on some of the 49 Liter topcase latches. Mine was off of a late model K1300GT and was repaired under the program. Check with your dealer.
    Greg
    Jun 2009
    Clearwater, FL
    Thanks for the info. Mine was purchased in 2006, so I am sure out of warranty. Will check with dealer.
    Bikeaholic Trickster's Avatar
    Alberta
    Don't be so sure its out of warranty, make the call and voice your concerns,
    you may be pleasantly surprised.
    Rick
    09 Hyosung Aquila GV250-08 BMW K1200GT Silver
    80/81 Honda CM/CB 400/450 "Frankensteined Bobber"
    79 Honda CX500 Custom Black -78 Honda GL 1000
    77 Honda CB 125 Sport-77 Suzuki TC 185 "10 speed"
