Well, we've added more USB power sources to our lineup.
In addition to our Cigarette To USB Charger Adapter and our Powerlet Mini-USB Power adapters, we've added a couple direct wire USB adapters.
Between the plug-in solutions and our new direct wire ones, you should be pretty well covered when it comes to powering or charging your USB gadgets.
New - Weatherproof USB Power Socket -
This handy unit wires directly to your battery or fuse block and gives you a weatherproof solution to plug in most of your USB powered devices.
- Input: 12V +/-4
- Output: 5V +/-0.25
- One Piece, All Weather Cap
- Cable Length: 6 feet
- Built in automatic resetting fuse
- Mounting Bracket Included
- USB Type A plug (same as on your computer)
Weatherproof USB Power Socket Details
Mini USB Power Socket -
Like the weatherproof USB Socket, this unit wires directly to your battery or fuse block and gives you a Mini USB port to power things like GPS's.
- Input: 12-24V
- Output: 5V at 1A
- Built in power converter and overcharging protection circuit
Mini USB Hardwire Details
Both of the direct wire systems work on 12 volt so, not only are they great on your bike, they will work on your Car, Truck, ATV, RV, and more.
