Results 1 to 3 of 3
Thread: Wondering GT
    Southwest Iowa
    Wondering GT
    Last summer at ~ 36K miles, my 08 GT started to "wonder" rather than track straight down the road. After experimenting with different tires, tire pressures, front wheel bearings and such, my dealer installed new ball joints in the front end. It took care of the problem. Now at 55K miles, the problem is starting to return. Again, I've switched tires and no help. I suspect the ball joints are going bad again. Has anyone had this problem?? My dealer says this is unusual and I agree, but it is very noticable and possibly not safe. It really stinks when you try pulling a trailer and this happens. Any input is appreciated.
    Apr 2005
    Same problem, different wheel
    I'm taking my GT in to get the rear wheel bearing replaced at 36000 miles. The bike displays much the same tendency''s you describe and judging by the forums is much more common.
    Southwest Iowa
    I had an 06 RT and had a final drive bearing go out (the big one that doesn't run in oil), but when it was bad I didn't notice an unstable ride-just a noisy one. My mechanic checked the bike today and also believes it's the ball joint again. We can feel a very small amount of "play" in the top one. It's hard to believe that small amount of play can translate into a very wobbly ride, but I guess it does.
