Page 1 of 5 123 ... LastLast
Results 1 to 15 of 62
Thread: Auxilliary Light Install KGT
    Aug 2008
    Kingston, NH
    The articles, posts and comments in this tech section are posted by individual members and reflect their personal thoughts and experiences with repairing, maintaining, and generally working on motorcycles. This information may require specific knowledge and skills, may or may not be correct or current to model.
    The authors of information found here and the BMW MOA take no responsibility for ensuring the accuracy of any information (including procedures, techniques, parts numbers, torque values, tool usage, etc.), or further for any damage of any kind or injuries incurred or caused by anyone following the instructions or information found here.
    It is the duty of the individual to either assume the liability himself for responsibly using the information found here, or to take the bike or accessory to a Dealer or other qualified professional service.
    Lastly, please ensure you dispose of your used chemicals, oils and fuels in an environmentally responsible manner. Most Auto Parts stores and service stations will accept used oil and lubricants, tires and batteries, please check for your local availability.
    This article, text and photos are Copyright of the individual authors and the BMW MOA, any copying or redistributing is permitted only by prior written authorization.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Aug 2008
    Kingston, NH
    The following DIY project will show how to install a set of auxilliary lights on a KGT, specifically a 2009 KGT 1300.
    NOTE - please check your local laws to understand the requirements associated with Auxilliary lighting.
    For example, in Massachusetts, it is a state law requirement that if the auxilliary lights are on, they are automatically turned off when the Hi-Beam on the main headlight system is activated.
    Instructions for shutting off the auxilliary lights when the high-beam is turned on are included in the DIY
    Aug 2008
    Kingston, NH
    PROJECT OVERVIEW
    The premise of this DIY is that I wanted to have auxillary lights on the bike mounted under the oil cooler area as in the RT, and I did not want to mount them on the caliper as others have. After some searching and vendor calls I realized they do not make mounts for under the cowl for the newer KGT.
    However I was provided a link for Jimmy Mounts from BMW Denver. These mounts are made specifically for the PIAA* Style lights so I ordered them. They mount under the rear view mirrors. I checked them out and they looked pretty good (to me) so they were ordered.
    * although made for the PIAA light it appears they will accept any vertically mounted style light
    Here is the link
    The project consists of 3 to 4 seperate steps.
    Step one - prepping and mounting the Jimmy mounts
    Step two - mount the lights to the Jimmy mounts
    Step three - lay out and install the wiring harness**
    Step four - modify wiring to support High Beam shut off of aux lights - check your local law requirements
    ** Please note that using the Jimmy mounts and the amount of excess wiring provided in the harness you WILL have to cut the harness and connectors in various places - this will obviously void any warranty provided by PIAA so please be fully cogninzant of this aspect of the install if you plan to do it.
    Aug 2008
    Kingston, NH
    Install Hardware 1
    Shown below are the Jimmy mounts, their hardware and instruction sheet.
    they are power coated black and are very robust - suitably able to support the PIAA Light
    Aug 2008
    Kingston, NH
    Install Hardware 2
    The lights and their accompanying parts
    Aug 2008
    Kingston, NH
    Bike Prep
    You need to get the bike to a usable access position to work on.
    The easiest is removing all the plastic and windshield to be able to properly mount, route and install the various items.
    This link shows how you how to remove all the plastic
    This link shows how to remove the windshield - please note you can stop when you get to post # 15 on this one
    Aug 2008
    Kingston, NH
    Jimmy Mount Preparation
    Shown here is the sequence of hardware that will be used to mount the Jimmy Mount to the bike.
    From left, it will be a Hex screw, with a washer, the plastic sleeve slides on next and then that hole combination is put into the mounting hole and then the hex bolt is threaded onto the bike supporting the mount.
    The hex bolt has a 5mm head.
    Aug 2008
    Kingston, NH
    Things to note - the first
    Check for flash on the plastic sleeve and remove it - this will provide a better fit
    Aug 2008
    Kingston, NH
    Second
    The bottom of the Jimmy Mount will flush mount to the side of the front cowl - even though I do not plan to remove the mounts I did not want to have the area damaged by the permanent contact, so I added some rubberized tape onto the mounting area to protect the painted surface that will be in contact here.
    Optional - not required
    Aug 2008
    Kingston, NH
    Shown is the mirror removed and how it would mate to the mount for install.
    DO NOT INSTALL - because you need to mount the lights first and route the light harness thru the mount before putting the mirror(s) back onto the bike.
    Aug 2008
    Kingston, NH
    Mounting the Lights
    OK - the mount is preped and we are ready to install the light onto the mount.
    The instructions call out that the small hole on the side of the mount is for the wire harness.
    As you can see PIAA provides some nice connectors that in no way will fit thru the hole.
    Here you have to choices:
    1 - you can leave the connectors intact and wire the lights with the harness outside of the mount
    2 - you can cut off the connectors and run the light wires thru the hole as provided.
    I went with option 2 because I wanted a clean look - but be advised any modification to the harness will void your warranty for the PIAA product, and probably any product you use.
    Aug 2008
    Kingston, NH
    Light Preparation
    Since I am going to cut off the connector, I wanted to identify/maintain the same wire polarities to the lights.
    I checked both connectors and if you pull them out straight you will note that one wire will be slightly longer (green arrow) because there was more slack, in my case, the longer wire in each connector is associated to the ground side of the wiring.
    So the shorter wire is postive, the longer is negative and it was the same for the other light.
    Aug 2008
    Kingston, NH
    I put a small piece of shrink tubing to identify the postive line and then did the same for the other light.
    Aug 2008
    Kingston, NH
    Mounting the lgihts to the mounts
    Displayed below is the assortment of hardware to mount the lights, depicted is the order of their assembly (Top to bottom)
    Aug 2008
    Kingston, NH
    OPTIONAL STEP
    The hardware supplied came with a standard nut, I did not think that was robust enough and replaced it with an M4 Nylock style to ensure that it would not come loose.
