Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 37
Thread: Gerbing Permanent Controller Install DIY
    Aug 2008
    Kingston, NH
    Securing the power side:
    The photo illustrates tying off the power cable to some wiring I'd added to the bike earlier. If you're working on a stock bike, I'd suggest securing it to the brake lines - with not-too-tight tie-wraps
    Aug 2008
    Kingston, NH
    Clean up of the power wiring
    Aug 2008
    Kingston, NH
    NOTE - as I already had a power connection I plan to splice into it
    Connecting the power
    Please note that by cutting into the original harness you will void the Controller warranty
    For a stock install you have 2 options:
    1. If you do not have a fuse panel of any kind follow the manufacturer's instructions to connect directly to the battery
    2. If you have a fuse panel connect to it at the appropriate current range (fuse), remember this device already comes fused with 15A fuse
    Aug 2008
    Kingston, NH
    Once the power line has been routed I connected the orignal cable from the Centech to the new wire.
    Part of the process includes cutting out the newly supplied in-line fuse (as I will be utilizing the previous contact point on the Centech panel (15A))
    Shop Tip 1 - add a small piece of shrink tube to identify the power side of the wire.
    Shop Tip 2 - pre-positioned a piece of shrink tube before crimping the ends together
    Aug 2008
    Kingston, NH
    The wires crimped - now to shrink over to provide some weather protection.
    Aug 2008
    Kingston, NH
    "Hot" side completed
    Aug 2008
    Kingston, NH
    Same thing with the ground.
    No need to identify the wire, just have a piece of shrink-tubing in place prior to the crimp installation.
    Aug 2008
    Kingston, NH
    The more you add to your fuse panel, the messier it gets.
    It is good practice to clean it up at the time of any new farkle install.
    Here the grounds and power are organized.
    On the left hand side (towards headlight) is the positive side, towards the gas tank are the negative (ground) sides. This is totally dependent on the type of fuse panel you have and where/how you located it.
    Aug 2008
    Kingston, NH
    Mounting the Controller
    Power and Ground completed.
    Let's mount the controller.....
    Aug 2008
    Kingston, NH
    The circled area will be the location where the adjustable controller will be mounted.
    I selected this area because it is a short and quick reach to the controller.
  11. #26
    Aug 2008
    Kingston, NH
    The adjustable controller.
    Note the nut, washer, washer, nut set up - this is explained in the instuctions.
    Note that the knurled knob pulls off with light pressure but retains well on the adjustment shaft
  12. #27
    Aug 2008
    Kingston, NH
    As the wires on the LED were moved around I noted that there was a small gap of the wire to the conformal coating on the Printed Circuit Board (PCB).
    To ensure weather protection I dropped a little bit of super glue to seal the openings.
  13. #28
    Aug 2008
    Kingston, NH
    This is a how I set up the alignment to drill the hole for the adjustment shaft and the hole for the LED.
    There are many different ways to approach this and shown in the following sequence is what I did.
  14. #29
    Aug 2008
    Kingston, NH
    In the location of where I wanted to put the controller adjuster I encountered an issue that the mounting pin of the panel was directly below the hole to be drilled.
    To address that the pin location was identified and a new location hole was selected.
  15. #30
    Aug 2008
    Kingston, NH
    Shown is the new location
