Results 1 to 15 of 20
Thread: Winter Storage Tips
    Payson, AZ
    Winter Storage Tips
    This is the first winter I won't be putting my bike in storage for winter. I've been reading about how to store it properly and have been given a few tips here and there. So far the tips are: use Stabil, fill the tank, cover the bike, plug the exhaust, battery tender, put it on the centerstand, and cover the ground with cardboard. Most recent tip was to put a light coat of WD40 on the chrome. Am I missing anything?
    I'm sure there are many threads out there but this thread is for the ladies; especially the ladies that don't have someone to do it for them.
    Thanks!
    Registered User BAClark's Avatar
    Jan 2008
    Storage tips
    I like to remove the spark plugs and add a little oil tot he cylinder. Otherwise all of the tips you have been given work.
    Payson, AZ
    Quote Originally Posted by BAClark View Post
    Spark plugs.....cylinder! You must be kidding...*
    Registered User womanridge's Avatar
    Jun 2007
    Milwaukee, Wisconsin
    Quote Originally Posted by sudani View Post
    LOL
    I love it!!
    Karen Jacobs
    Moderator
    2012 R 1200 RT
    MOA-133005, RA32109, IBA #37923
    Cage Rattler wezul's Avatar
    Nov 2006
    Glen Ellyn, IL
    And then rotate slightly.
    Know what I mean?!
    Registered User DaleStrunk's Avatar
    May 2008
    Klumbus, O H I O
    I hates winter more and more.
    Gonna be doing all that, and my K100, sits in a stand in a heated insulated garage.
    Survivor akbeemer's Avatar
    Jul 2007
    Land of the Big Sky
    It is a good idea to have fairly fresh oil in the bike if you are going to store it for a few months. Well used motor oil, with the by products of combustion in it, can get acidic and harm the machined metal surfaces in the engine. I do not know if there is a definitive limit on the number of miles the oil should have on it when it goes in storage, but I try to have less than 2-300 miles.
    Kevin Huddy
    Intrepid Incompetent
    Tm Pterodactyl MT Outpost
    larrydk
    outside
    I've always kept my bikes in my unheated, unattached garage in the winter. I usually poll them over some cardboard or floor mats since moisture tends to come up from garage floors in the winter.
    I also try to get the bike out at least one time a month for 30-40 minutes as long as its dry (snow messes this plan up often)
    Aug 2008
    Kingston, NH
    In addition to everything.....
    Also you may also want to block up the intake(s)
    Depending how cold it gets you may just want to remove the battery and keep it charged in a nicer environment.
    If you can keep both tires up of the ground that will minimize any flat spots later when you get ready to ride it
    I plan to have mine on the centerstand and the front wheel stand GT and for my wife's ST I plan to put it on the center stand and then lift up on the engine a bit.
    A nice coat of fresh wax and you should be all set.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Payson, AZ
    I'm paying attention...
    and planning on doing many of your suggestions. Thanks for sharing. I'd like to think that preparing for the winter will make Spring that much easier.
    All tips accepted!
    *L* I've done the warm year round thing. Not sure I'm ready to do it again, just yet.
    Jul 2007
    Land of the Big Sky
    There is also the advice I often receive and made immortal by this fine gentleman......
    MOVE!!!! (to a warmer climate)
    Kevin Huddy
    Payson, AZ
    After spending a week in Payson, it's mighty tempting! The roads up there are just crazy. A few more years of practice is in order before heading there on the bike.
    Have you ever gone to the "too broke for sturgis" rally?
    Once there was a Tavern PAULBACH's Avatar
    Dec 2005
    Ballston Spa, NY; South of the Adirondacks, North of the Catskills and West of The Berkshires and Green Mountains
    From Shameless Trolling For Touring Tips
    I love travel whether two wheels, four wheels or two jet engines on a commercial aircraft. For all around excellence covering the BMW world it's hard to beat our own Owners News and the RA's OTL.
    But for Touring, RoadRUNNER magazine fills a special niche. It's one of my top three along with Motorcycle Consumer News. RoadRUNNER also has a monthly newsletter and a cool new book coming out in December. If touring is in your blood their new book available in December would make a wonderful gift.
    From the latest newsletter is some great advice for those of us who live north of the Mason Dixon line and hook our bikes up to battery tenders.
    Touring Tip: Checklist for Winterizing Your Bike
    "Because most mechanical systems perform best when they're used regularly, the most effective way of preparing your bike for winter is to simply keep riding and maintaining it. But most of us, unfortunately, don't live in a climate that allows a 365-day riding year. Consequently, we need to prepare our rides for some period of winter storage. Here's a quick checklist to help you make sure the job gets done properly:
    • Store Properly: Indoor (heated if possible) storage is best for guarding against moisture and rust. To prevent flat spots from developing on tires, store the bike on its centerstand with most of its weight off of the wheels. If that's not possible, move the motorcycle slightly every month.
    • Stabilize the Fuel: Fill gas tank and add fuel stabilizer to the gas. With fuel-injected bikes, run the engine so the treated fuel gets into the injectors. With carburetor(s) turn off petcock, drain float bowl(s).
    • Tend to the Battery: Attach maintenance charger to battery. If battery is a non-sealed type, check fluid levels and add distilled water if needed. Avoid using trickle chargers, which overcharge batteries in storage
    • Lubricate Controls and Other Mechanical Parts: Lubricate cables, change front fork oil as required by owner's manual and oil other exterior unsealed moving parts.
    • Change Engine Oil and Filter: Because old oil can develop acidic qualities and cause corrosion, change it prior to storage and possibly again in the spring.
    • Inspect/Lubricate Final Drive: Chains should be cleaned, checked for proper tension and lubricated. Check the oil level on shaft drive bikes and add or replace it as Inspect/Service Cooling System: For water-cooled bikes, test the coolant for freeze protection. Look for any signs of rust or leakage, ensure that coolant level is at the proper level--drain and flush and replace coolant every two years.
    • Inspect/Service Brakes: Remove the brake pads and check the calipers for corrosion. If left unchecked, corroded parts can eventually cause brakes to seize up. Replace faulty parts as necessary.
    • Inspect/Replace Tires: Check condition of tires, including tread depth. Tires with wear bars showing or 3/32 or less of tread remaining, or older than six years should be replaced.
    • Inspect/Service Electrical System: Look for any signs of corrosion on exposed electrical connections. A thin coating of silicone dielectric grease can help prevent corrosion.
    • Replace Brake/Clutch Fluids: Brake fluid can absorb moisture over time, causing corrosion and loss of braking effectiveness. It's best to replace those fluids yearly, but be sure to use only the recommended fluid from a sealed container.
    • Check Torque of Threaded Fasteners: Ensuring that key nuts and bolts (i.e., those that could threaten life or limb if they became loose) are at their proper tightness is especially important.
    • Clean/Protect Surfaces: Give your bike a thorough cleaning and then polish and wax all painted and chrome surfaces; clean and polish aluminum and stainless steel surfaces with the appropriate metal polish and then apply a protective coating.
    • Inspect/Replace Air Filter: Inspect the air filter to determine if it needs cleaning or replacement.
    • Clean and Treat Leather: Using a high quality dressing to clean and preserve all leather surfaces.
    • Treat Cylinder Walls: To help prevent cylinder wall and piston ring corrosion, remove spark plug(s) and add 25cc of motor oil. Then, with plugs removed, use the starter to turn the motor over several times to distribute the oil. Reinstall spark plugs and tighten to the specified torque.
    • Consult Owner's Manual: As a final check to make sure you haven't missed anything, review the maintenance schedule in your owner's manual to determine if any other services are required.
    Many, if not most, of the above procedures will be within the mechanical knowledge and skill level of the owner. However, if you're ever in doubt about something, it's always advisable to consult a trained professional technician.
    Ride safe and we'll see you again next month."
    "Reprinted courtesy of RoadRUNNER Motorcycle Touring & Travel magazine (www.roadrunner.travel)"
    Check out RoadRUNNER's website at RoadRUNNER Magazine.
    Payson, AZ
    Paul,
    I enjoy RoadRUNNER magazine. What got me to order it were the maps and the gps downloads available online.
    Dec 2005
    For the Touring Community, RoadRUNNER is one fine magazine. Of course Owners News is in a special class.
