Results 1 to 12 of 12
Thread: Kickstand no start switch
    Registered User xp8103's Avatar
    Apr 2008
    Maine
    Is there a way to disable the kickstand down/no start feature of our bikes?? Is there some sort of terrible horrible no good very bad damage I'd do if I were able to start and run my R on its side stand??
    Nik #140220 - '88 K75C | '96 R1100RS | '77 R100RS | '06 DL650
    '01 525iT (oOO=00=OOo)
    Helmets don't save lives but loud pipes do?
    Oct 2003
    If you follow the wires up from the switch, there's a connector along the left side. If the switch fails, and the early ones have a reputation that way, you could disconnect the switch at this point and install a jumper instead.
    There's nothing wrong with running the bike on the sidestand. What's wrong with permanently disabling the switch is that when you forget to retract the sidestand and ride away, you could go for a high side on the first left turn, or even on a highly crowned road.
    This is why the sidestands on all the airheads and even the optional one BMW supplied for /2s were all spring loaded retracting types.
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by xp8103 View Post
    Not sure what you are trying to accomplish here -- if the bike is in neutral, it will run with the sidestand down, i.e., there is nothing preventing you from running the bike on the sidestand, while still having the anti-ride-off-with-the-stand-down feature enabled.
    Florence County South Carolina
    Quote Originally Posted by mneblett View Post
    Depends on what year the bike is. my 99 RT would not start or stay running with the sidestand down. I disabled mine.
    Apr 2008
    Maine
    Actually, no. Mine will not start (will not even be "on" even tho the key is on) with the side stand down. I can turn the key on and nothing happens. Once I lift the side stand, the IP turns on, the fuel pump purrs and the starter is enabled.
    At least on the K, there is a connection to the clutch lever that retracts it on first operation of the clutch.
    On my 99 RT there was an insulator where the sidestand mounts. I simply removed it. I removed the bolt holding the sidestand to the frame. then I slid the Insulator out, and replaced the bolt. I didn't mess with any wires. the Germans had it so that the bike wouldn't start till the side stand was grounded. when you raised the stand and it hit the frame it was grounded. when I removed the Insulator it causes the stand to be grounded all the time. hope this helps some...
    Apr 2008
    Maine
    Quote Originally Posted by kgadley01 View Post
    thanks! Will crawl under it and look for the insulator.
    Calgary
    The best option is to wire a relay in parallel with the sidestand switch. The relay is then powered byt the neutral light so it completes the circuit as long as the tranmission is in neutral. When the shifter is moved into gear, the relay will open and if the kickstand is still down, the engine will quit. Keeps the saftey feature working and eliminates the nuisance factor.
    The later model oilheads were configured this way from the factory.
    Ed Miller, Calgary, AB
    2008 K1200GT, 2009 F800GS
    I can't wait to retire and have a fixed income. The one I have now is always broke.
    Nov 2005
    Fairfax, VA
    Thanks for the correction! I didn't remember that from my '99RT.
    Mountain King JAMESDUNN's Avatar
    Mar 2008
    Des Moines, Iowa
    Mine is disabled! It quit working and I have bought a new one, but looked it over and have not installed yet as it looks like a PITA. I'll do it soon however. I don't think it is a good idea to disconnect, as I occasionally ride off on mine with the side stand down. So far no problems but it is unsafe in my opinion.
    1994 R1100RSL, '78 R100RS
    "Ride hard or stay home."
    Apr 2004
    Warren Ohio
    Quote Originally Posted by MCMXCIVRS View Post
    I used the RTP parts from the IBMWR web site and it works great. No cutting into the wiring. If need be you can use the relay to replace a bad starter relay.
    http://www.ibmwr.org/r-tech/oilheads...nd_start.shtml
    01 R1150GS
    75 R75/5 Toaster LWB Red
    Al Navecky Jr
    Registered User 116318's Avatar
    Nov 2005
    Byron Center, Mi
    Side stand switch
    I have had my 1998 r1100gs for about 3 years now and I have become very use to putting my side stand down when I stop it turning off my bike. I like the idea of the new Ga's that you can start in neutral of for whatever reason and get off your bike and leave it running. So today just for grins I shorted the side-stand connector under the seat and took a right down to my local gas station for a fill up. Once there I found I had to use the kill switch to shut her down ( just a little confusing ) but on the way home I stop suddenly to help someone and because I was so use to the putting my kickstand down to kill the bike, I found myself fumbling and fiddling around, wasting time before I could help anyone. Once back home I decided this was a safety issue and put removed the short. I will do the relay setup in the near future. Because of the habit of stopping the bike with the sidestand and not the key or kill switch is just to risky . ( ok no check spell but you get the idea. )
