Results 1 to 13 of 13
Thread: RT Headlights Aimed Too High?
    Mar 2009
    5,000 miles on my '09 RT.
    When I ride at night, I can see my headlights illuminating the reflective overhead freeway signs. The nearby cars don't do this, which leads me to believe that my headlights may be aimed improperly. Been this way since new.
    Any words of wisdom? Could this be normal? I seem to remember that the proper procedure for aiming auto headlights is a bit involved, requiring specialized equipment, more than just a level driveway and garage door, which I don't have anyway.
    I would hope that the headlights would come properly aimed from the dealer, but who knows?
    Increasing rear spring preload helps a little, but does not eliminate the problem.
    05 R1200RT jenkenj's Avatar
    Nov 2004
    Vancouver BC
    Check your manual for the location of the headlight adjustment lever. It is on the left inside of the front fairing and is used to raise or lower the headlight assembly if you are carrying a load or passenger. It has two positions, yours might be set on the higher of the two and its easy to flip it over to the lower and vice versa.
    Jeff
    Jeff
    Mar 2009
    Wow, Jeff, I didn't know there was such a lever. I'll check it out.
    Thanks.
    Seeking the 4TH dimension _RockZ_'s Avatar
    Feb 2009
    Medford,MN
    wow I had the same problem when I put a lowering Shock in so what Did I Do?
    if you pull off the left side mirrior hang on to it it will come right out after a little tug and when you look in there is a hex head plastic screw that runs the vertical control and on the left side there is the same screw that runs the horizontal control so I used a 12mm socket (beacause it is easier to hold on too) few turns moves it,so know you now where the adjusters are now follow the MOM (motocycle owner manual) and Good Luck!
    Friend of Bill W. Kiss the Wife.Love the Kids.Live the Day.
    2005 R1200RT
    MOA#147877
    Registered User texanrt's Avatar
    Nov 2008
    Houston
    R1200RT Headlight Adjustments
    Unfortunately, the owner's manual doesn't tell the whole story.
    Quoted from the thread linked below:
    Here's what I found out.. There are two adjustments on the RT, one on the bottom right (looking over the Speedo/Tach, and one on the top left. The one on the bottom right will change the beam left / right and the one on the top left does the up/down. I had the same problems you describe, but a few trys with a 12 MM socket and mine settled right down.. On the upper left one, there is a lever that will adjust for two up riding. It lowers the beam to compensate for the rear settling lower.. The owners manual describes it so be sure (if you intend to use it) that it is positioned properly while you adjust..
    http://www.bmwmoa.org/forum/showthre...ent#post425790
    Texan RT | Houston | IBA
    BMW R1200RT | HD Road Glide
    Smile R1200RT Headlight Aiming
    Once you find the Headlight Module elevating screw, use a 13mm socket with a 3" extension on your ratchet wrench to turn the adjuster CW (clockwise) to RAISE the headlight, or CCW (counter-clockwise) to LOWER the headlight. How much you'll need to turn it depends on how much adjustment it needs!
    Ideally you should be sitting on your bike while your assistant makes the adjustments, but don't let the bike sit idling for much more than a few minutes: She can overheat and melt things. Better to aim the bike towards a wall, note where the headlight falls on the wall, shut off the engine, make an adjustment, restart the bike, note where the headlight now falls on the wall, shut off the engine again, make another adjustment, repeat until satisfied with the aim. What a fantastic motorcycle the R1200RT is! Thanks BMW.
    May 2011
    Smile
    Turn the adjuster, go for a ride. I set mine so it will not shine into the back window car on low beam. It still illuminates the signs on the side.
    I set my spring preload so the light shines the same as before I was loaded.
    David
    2012 R1200R 24,000 MIles
    2011 Versys 14,000 Miles
    2000 R1100RT 140,000 miles
    Wilmington, NC
    In direct answer to the original post, the behavior of your 09 RT is normal. Pretty much every RT I've looked at from several years around that time period, including mine, was delivered with the headlight set too high at the factory. I don't know how they did it but they were quire consistent in getting them high by good amount. You can find threads about it on various sites if you search.
    Finding the adjuster on mine happened the first week I had it. The little white lever doesn't provide anywhere near the range needed to compensate for how far off the factory was. Takes a wrench on the real adjuster
    I wondered if they simply set them with unloaded bikes that had no gear, cases, or fluids..
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Maybe no setting going on at all, but merely assembly of the mechanism until the adjuster runs out of threads. Maybe the factory says "aim headlight" is part of the uncrating and setup the dealer's supposed to do.
    David Brick
    Santa Cruz CA
    2007 R1200R
    May 2011
    Riding my R1200R home from the dealer, the headlight was set for coon hunting. I could see in the trees great. Luckily it was not even tight so I just turned it by hand.
    David
    JoeDabbs
    Sep 2003
    Virginia Beach
    My dealer says they all come aimed at the sky...
    Joe Dabbs
    2011 RT
    1975 R60/6
    Registered User Trojan's Avatar
    Jun 2012
    My '09 RT needs a little downward adjustment too. I happened to notice this excerpt from another post on another forum....
    As to the two adjusting hex knobs on the back of the headlight module....BMW tool kit trivia...the oil filler cap removal tool has a hex portion that can be used to adjust the headlamp knobs.
    How clever/handy is that??
    John
