Results 1 to 13 of 13
Thread: Tell me about grooved pavement
    perniculous
    Where I live in the nordlichlanden there are many miles of grooved pavement. Going over that stuff always feels squirrely and weird. Tire pressure, check. Good tread, check. Any thoughts on warding off the weirdness?
    Manitowoc, Wisconsin
    In my humble experience, similar to riding on grating, don't hang onto the bars so tightly. I describe it as not steering the bike, but guiding it, suggesting the desired direction. Gripping the bar firmly feels unnerving in that situation.
    F.O.G.Rider, Rounder #6,
    Ambassador, Biergarten co-chair
    BMWRA Wisconsin Region Rep, camping chair
    tires with lateral rain grooves (more of a front-to-back pattern, like the old Conti RB-2) tend to track the grooves more... and that feels more weird.
    mostly just relax on the bars, and realize that it's only feels weird... but not very likely to actually upset your traction.
    JAMESDUNN
    Quote Originally Posted by manicmechanic View Post
    Agree with above. Also, the tires you're using make a difference. Tires with more "linear" designs will tend to chase rain grooves as oppossed to the newer types that feature more asymetrical tread patterns.
    "Road Worthy" LRider's Avatar
    Aug 2004
    Ottawa, Canada
    Just relax and guide, as said above. You still have lots of traction. If it helps, imagine you are on a gravel road.......
    Cheers............Rod
    BMWMOA# 114168 IBA# 19606
    "Road Worthy": http://www.trafford.com/Bookstore/Bo...=SKU-000167680
    SW Ohio
    Tires can make a HUGE difference. Once you know it's just the rain grooves and not
    a flat, loose wheel, oil, cracked frame, steering head bearings, or rider acid flashbacks,
    it's not so bad.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    perniculous
    Thanks ya'll!
    Sep 2003
    Virginia Beach
    Slight acceleration has always tamed them for me.
    perniculous
    Quote Originally Posted by 35634 View Post
    it's not so bad.
    I have a set of Dunlop Sportmax on my bike.
    Still Wondering mika's Avatar
    Aug 2004
    Fly Over Land
    Where you ride in your lane can make a difference.
    In the past I had stretches of grooved pavement as part of my daily commute. I conjunction with the good advice previously given I found myself moving my lane position slightly as I rode these stretches. Over time car and truck traffic takes some of the edge off rain grooves as the road wears in but not uniformly over the width of a lane. Moving my lane position a bit to the left or right put me in the worn part of the road. I still had to apply Manicmechanic's riding technique but found it easier to do so if I watched where I was in my grooved lane.
    Pass the mustard and UP THE REVOLUTION!
    St. Paul Pioneer Press , Minneapolis Star Tribune
    Dec 2007
    Reno, NV
    Avoid tires with continuous center grooves. This will not obviate, but will help, with the problem. The grooves are cut by different machines, with different groove spacings. So it is not possible to design a tire that works for all rain grooves. If I change tire brands, or bikes, different sections of hiway become more problematic.
    Do not death grip - ride looseley.
    Maintain your steering head bearings, shocks, forks, swing arm bearings, etc. Keep everything lubed and tight. Sloppy steering head bearings, marginal tires, plus rain grooves could be, um, exciting.
    I grew up on the rain grooves.....
    X-Mileage tabulator R1100rtp's Avatar
    St. Paul, MN
    Quote Originally Posted by Mika View Post
    I just rode the RT over Trail Ridge Road....couldn't figure out why they had a warning sign at the bottom.....Caution Grooved pavement MM440) Actually it was road repair, and happened to be on a right hand 15 mph switchback. Interesting, but survivable. Metzler Z-6s (I think)
    Ride Hard, go far, and keep smilin...
    Karol Patzer, Ambassador, 2014 BMW MOA Rally Chair
    Visit St. Paul July 24-27, 2014
    Registered User rottenbiker's Avatar
    Colorado
    Colorado
    Hey Karol where are you now? need a place to stay? We are down in Loveland
    Marsha Hall
    2012 GS Rallye, Vespa 250GT, Iron Buffalo Motorcycle Training, lead rider coach
