Bike is a '94 R100RT. Transmission oil is dripping from the shift linkage where the linkage attaches to the transmission case.
I have never had the shift linkage apart so I would like to know what is required here and what type of seal this is. A bolt with an internal hex recess attaches the mechanism to what I believe is a shaft inside the transmission. I have heard that it is not necessary to get inside the transmission to replace this seal. Correct?
If I remove this one bolt, can the linkage to be moved aside for seal replacement?
