Page 1 of 4 123 ... LastLast
Results 1 to 15 of 46
Thread: HEXHEAD Tech - R1200X - Valve Adjustment - All Years
    Aug 2008
    Kingston, NH
    The articles, posts and comments in this tech section are posted by individual members and reflect their personal thoughts and experiences with repairing, maintaining, and generally working on motorcycles. This information may require specific knowledge and skills, may or may not be correct or current to model.
    The authors of information found here and the BMW MOA take no responsibility for ensuring the accuracy of any information (including procedures, techniques, parts numbers, torque values, tool usage, etc.), or further for any damage of any kind or injuries incurred or caused by anyone following the instructions or information found here.
    It is the duty of the individual to either assume the liability himself for responsibly using the information found here, or to take the bike or accessory to a Dealer or other qualified professional service.
    Lastly, please ensure you dispose of your used chemicals, oils and fuels in an environmentally responsible manner. Most Auto Parts stores and service stations will accept used oil and lubricants, tires and batteries, please check for your local availability.
    This article, text and photos are Copyright of the individual authors and the BMW MOA, any copying or redistributing is permitted only by prior written authorization.
    NOTE– products used are by personal choice and do not represent any affiliation to the product lines.
    Specifics:
    space-Bike shown is a 2008 R1200RT
    space-Heated Seat Option
    space-No Factory Radio
    space-BMW Cylinder Guards
    Tools
    (top down)
    - 3/8” Drive ratchet and extensions
    - 10mm Combination Wrench
    - 0.30mm Gap Tool - Exhaust Yellow Handle (BMW) 2x
    - T-45 Torx Head Socket
    - T-30 Torx Head Socket
    - Spark Plug Coil Removal Tool – Reference www.marcparnes.com
    - 0.15mm Gap Tool - Intake White Handle (BMW) 2x
    - 3mm Allen Wrench
    - Metric Feeler Gauge Set
    - Extended Reach 5/8” Spark Plug Socket
    space- Reference www.harborfreight.com Item number 91705
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Aug 2008
    Kingston, NH
    1 - Place bike on center-stand and have suitable waste oil receptacle nearby to place underneath the respective valve cover being removed.
    2 – You do not need to remove the plastic panels to do a valve adjustment – but a valve adjustment is usually followed by a Throttle Body Sync.
    For details on how to remove the panels , please refer to this link http://www.bmwmoa.org/forum/showthread.php?t=35262
    For details on how to conduct the Throttle Body Sync, please refer to this link http://www.bmwmoa.org/forum/showthread.php?t=35446
    REMOVING VALVE COVER GUARD – below is shown the removal of the BMW Valve Cover Guards, if you do not have these, you can skip to the section on removing the valve cover itself. If you have another type of after-market guards refer to the installation instructions/user guide to remove.
    You will be removing 3 T-30 Torx the first is shown:
    Aug 2008
    Kingston, NH
    #2 of 3
    Aug 2008
    Kingston, NH
    #3 of 3
    Aug 2008
    Kingston, NH
    Cover removed with the respective screws - note the middle one is longer, this is important on reassembly!
    Repeat for other cylinder
    Aug 2008
    Kingston, NH
    VALVE COVER REMOVAL
    The following pertains to both valve covers
    The steps are as follows:
    1 - Remove Spark Plug Coil Cover
    2 - Remove Spark Plug Coil - special tool required
    3 - Lay Spark Plug Coil and harness across Throttle Body/Intake
    4 - Loosen 4 T-40 Torx bolts
    5 - Remove Cover - note small amount of oil will spill out - have something below to catch the oil.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Aug 2008
    Kingston, NH
    Removing the Spark Plug Coil Cover
    The cover is made of plastic - pinch here by where the Spark Wire exists the cover and pull off the cover towards you - set aside.
    Aug 2008
    Kingston, NH
    This is the Marc Parnes tool to remove the coil.
    Please note the highlighted area - it contains a notch which fits snugly into the groove of the spark coil.
    Aug 2008
    Kingston, NH
    Groove Detail on the Spark Coil
    Aug 2008
    Kingston, NH
    Squarely fit the spark coil removal tool onto the spark coil.
    Note 1 - if it is not fit squarely to the coil groove and you pull out you may damage your coil - DAMHIK
    Note 2- my thumb is intentionally placed in this position so the placement of the tool could be observed.
    Once properly fit - pull straight out - it will be snug
    Note 3 - for ease of next removal you may want to apply a little silicone spray (sparingly) to the inside of the spark plug tube.
    Aug 2008
    Kingston, NH
    Coil popped out
    Aug 2008
    Kingston, NH
    Once coil assembly has been removed off of the spark plug - lay aside and out of the way.
    Aug 2008
    Kingston, NH
    Before removing the valve cover it is a good idea to blow out the spark plug area out with compressed air to get rid of
    any debris before you remove the plug.
    Aug 2008
    Kingston, NH
    After the plug recess hole has been cleared you can remove the valve cover.
    Using a T-40 Torx remove the 4 highlighted bolts.
    Please note that there will be a small amount of oil that will be lost during the cover removal, ensure you have an appropriate device to capture the spill.
    RECYCLE NOTE: for proper disposal of waste fluid please refer to this link to find approved recycling centers in your area http://earth911.com/ - special thanks to Ted for providing the link.
    hjhjh
    Aug 2008
    Kingston, NH
    With the cover removed you can now access the valve train.
    Please note that there is a gasket seal for the spark plug which sometimes does not come out when you remove the cover.
    You will find it in the highlighted area - please remove.
    PART NOTE - the valve cover gasket is very robust - there is no need to replace it. Treat it with care and you can reuse the gaskets many times with no issues.
