Honey Badger
Lube the o-ring slightly with gear oil as that will facilitate re-insertion – do not pinch or cut the o-ring as you will develop a leak.
Push in firmly and evenly - you have to ensure proper seating and fit of the o-ring.
Once done tighten it with a T-25, the specification is 4Nm but i do it hand tight.
Honey Badger
SPECIAL NOTE - please ensure that the wire harness for the speed sensor is properly routed and clipped into the right locations. See highlight.
If not, due to its proximity to the disc there is high potential for chafing and damage.
Honey Badger
At this point the rear drive has had its fluid changed.
The only thing left to do is install the rear wheel and relocate the muffler back to it's orginal position.
Install the wheel and tighten the wheel bolts to 60Nm in a cross-star pattern (alternate opposite bolts.) Use care not to topple the bike off the centerstand.
Honey Badger
Re-align muffler and put back the muffler bolt in hand tight, as you need to double check some alignment points before final torquing
Honey Badger
Double check and confirm muffler clamp to muffler alignment mark are set correctly and hand tighten
Honey Badger
As muffler is held statically, check for tire to muffler spacing is even and about 10mm.
Adjust as necessary - once set then you can torque everything down.
Muffler Bolt = 19Nm Muffler Clamp = 55Nm
Check for leaks
Fluid Change DIY COMPLETED
Go ride
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
Forum Rules
