Results 1 to 4 of 4
Thread: Final Drive Leak
    mikea
    Final Drive Leak
    Sorry, I somehow managed to post a question about a leaking final drive breather cap on the oilhead forum. Anyway, to repeat, I have replaced the o ring with a 12x17mm o ring and the leak continues. Not as bad but it's still there. Any help will be much appreciated.
    Thanks, Mike
    James.A
    Final drive leak-breather
    Is it over-full? That would be the first thing I'd look at on any assembly with a breather leaking. The final drive, being the lowest point of the driveline, has the potential to end up holding more oil than intended.
    mikea
    Final Drive Leaking
    woodnsteel- Thanks for the reply. I checked last night and yes indeed the final drive was overfilled. I drained some out. How in the world does the oil level grow?
    Mike
    James.A
    The short answer is that it drains into that chamber from somewhere further upstream in the drive-line.
