Results 1 to 11 of 11
Thread: What is the recommended trickle charger
    Three wrongs make a right GSSteve's Avatar
    Aug 2005
    Eastern Ontario
    I have a 2004 GS ADV and a 2008 1200 RT (my wife's) parked in the garage as I wait for the winter to go away. I have to admit I do little winter prep on the bikes. The garage is semi heated. I do fire them up every couple of weeks (rightly or wrongly) but clearly the battery juice is low. What would you recommend for a charger that I could leave on and rotate between the two bikes or possibly purchase 2.
    Go North
    Once there was a Tavern PAULBACH's Avatar
    Dec 2005
    Battery Tender makes great products. They make one model that will service two bikes. But, for flexibility, would get two separate tenders.
    Check out their web page here.
    Paul Bachorz - F Twins Moderator
    RA Rallymeister - Pownal, Vermont
    Click here.
    Aug 2005
    Eastern Ontario
    Thanks! Will follow your suggestion and get one for each bike. It's about time that I do
    Go North
    Dec 2005
    Generally you will find the trickle charger will pay for itself by extending the life of the battery. A slowly charged, fully charged battery can last up to twice as long.
    Click here.
    Focused kbasa's Avatar
    Quote Originally Posted by GSSteve View Post
    They make one that can support 5 bikes for only a little more than buying two regular battery tenders.
    Dave Swider
    Marin County, CA
    Dec 2005
    5 Bank Charger - 12V @ 2A $587.95
    Click Here
    Battery Tender Plus 12V @ 1.25A $64.95
    Click here
    Battery Tender Junior 12V @ 0.75A $39.95
    Click Here
    Click here.
    Registered User PHMARVIN's Avatar
    Oct 2003
    El Paso, TX
    Hi,
    Battery Tenders have the reputation for working and have been around for a number of years. I went to Harbor Freight and, for less than $10, bought a float charger. That's what I use on my bikes (I have 2 bikes and 2 float chargers) to keep the batteries charged.
    Ride Safe,
    Phil Marvin - El Paso, TX
    '94 K75A/3
    '95 K75RTP
    State of Confusion
    Also make sure you check Gel versus "old school" battery
    -=Brad
    taller than wide GRANTMACEACHERN's Avatar
    Ontario
    Since you are in Canada
    This might be an option too:
    http://www.canadiantire.ca/browse/pr...romSearch=true
    I bought one of these a 2 years ago and it has worked fine. I honestly don't know if there is any difference between this one, a Battery Tender or a BMW battery minder but I've never had a dead battery.
    Follow the advice from the poster above and make sure you select the right switch for your style of battery before charging.
    I noticed that this charger goes on sale about every three months at Cdn Tire. It might be too late to catch a sale this season but there's the info.
    But here is my question to the group: The Battery Tender website notes that their chargers are for LEAD ACID batteries. Does that mean wet only? Are they intended for Gel batteries (i.e. my BMW Gelbatterie)
    G
    g r a n t
    Dec 2005
    *Note: All Deltran battery chargers will charge all types of lead acid batteries: either flooded (standard STD), sealed maintenance free Absorbed Glass Mat (AGM), or sealed maintenance free gelled electrolyte (GEL) batteries. However, for optimum battery performance in deep cycle applications (for example, running a trolling motor), it is best to chose the Deltran charger that has the charging software specifically designed for the battery type. Fortunately, since the technical staff at Deltran has developed charging software that works equally well for both STD & AGM batteries, the only choice to be made is between 2 models: either STD & AGM or GEL software.
    Source
    Click here.
    undercompensating BUBBAZANETTI's Avatar
    Jul 2004
    NYC and the world at a moment's notice
    Quote Originally Posted by BradfordBenn View Post
    battery tender jr (the cheap little one) will tend all batteries just fine.
    also, don't start your bikes if you're not going to ride them. change the oil before you put it away and you're fine.
    04 GS ADV
