Results 1 to 8 of 8
Thread: Need a Front Brake Expert
    Prime Time BobZ's Avatar
    Apr 2004
    Bourbonnais, IL
    Front brakes are not releasing as quicky as they should. Master cylinder, return hole and all recently cleaned and looking ok.
    Curiously, when rolling backward brakes release immediately. Any ideas out there?
    Thanks.
    Live Well, Do Good Work, Ride Safe.
    1978 R100S MOA #104733 ABC #7413
    1993 K1100LT KOG #997 CRBMWOA
    Jul 2007
    Evansville, WI
    Would think more along the lines of a sticky pad, try yanking the pads and running a small wire brush, like a soldering brush, through the calipers where the pads contact the caliper.
    Gilly
    87 K75S, bought new, now sold
    13 C650GT
    MOA 44606
    Apr 2004
    Bourbonnais, IL
    [/Would think more along the lines of a sticky pad, try yanking the pads and running a small wire brush, like a soldering brush, through the calipers where the pads contact the caliper.
    I'll give it a try. I was thinking along the lines of a sticky caliper but wondered why it wasn't sticking while rolling backwards.
    . AntonLargiader's Avatar
    Jul 2004
    Charlottesville, VA
    Are they stock pads? They could be hanging up on the guide pins, especially if they are aftermarket pads without the anti-rattle springs.
    Anton Largiader 72724
    largiader.com bmwra.org
    Apr 2004
    Bourbonnais, IL
    Probably BMW pads as they were installed 14k miles ago during a dealer service by previous owner.
    I have since changed the fluid.
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Quote Originally Posted by BobZ View Post
    The pads aren't retracting because a) the bores are less than mirror-smooth, and b) the piston seals are hanging up on the bore as they move in the bores.
    The pads move laterally within the bores a tiny bit. When you move forward, the pads are pulled forward (laterally) in their bores as they follow the disks; when you move back, the pads move the other direction. The reason they don't hang up when you move backward is the "rear" portion of the bores is smoother.
    If you go in there to smooth the bores, change the piston seals, too.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Apr 2004
    Bourbonnais, IL
    David,
    That makes sense. Sounds like a little caliper rebuild is in order.
    Thanks.
    Santa Cruz CA
    Let us know.
    Another reason for non-retraction is hardening of the seals, so they don't stretch as the pads reach for the disk and retract by hysteresis when the hydraulic pressure is eased. It's another reason for renewing the seals.
    David Brick
    Santa Cruz CA
    2007 R1200R
